Your shampooer is not broken. (sorry Fanny)
You are missing a wee screen that fits on the hole where the little hose plugs into the tank. Check inside the hose end or down inside your shampooer box. Here's a link to my online Kirby shampooer instructions...
http://reviews.ebay.com/KIRBY-CARPET-SHAMPOOER-INSTRUCTIONS-MANUAL-DIRECTIONS_W0QQugidZ10000000004594992
Hope I helped!
Marci
Make sure the foot pedal is to the lowest setting to the floor. Or the little screen at the end of the hose connected to the shampooer container.
The machine is not producing enough foam to fill the tray. If the carpet is saturated with water instead of foam, the foamer is faulty. I would return it for repair under warranty.
Here's my online guide for using the Kirby shampooer....
HOPE IT HELPS!!
Marci
I have the same problem, and the screen is in place and the filter is clean.
Thanks
shampooer is not producing enough suds--filter is clean, and the small screen is in place--what else can i do
I have the same problem and it is not the suds-ing screen! It is in the right place and I have cleaned it and made sure that everything is in the right spot....what to do?
I had the same problem and it wasn't the screen! It was the actually brush, it wasn't in straight. Once we took the brush out and put it in straight, wa-laa it worked!
what and where is the foamer?
