HOW DO I DELETE ERROR F2 04 AFTER INSTALLING NEW TONER CARTRIDGE
SOURCE: system error [f02-04]
I believe you asked the same question before.... Make sure the waste toner cover / plug is removed and that you shook the cartridge to loosing the toner. You may have recieved a bad or defective toner cartridge...Good Luck
SOURCE: Having trouble installing a new toner cartridge in a Sharp 168D.
Much sorry. You should peacefully understand. On cassette there is hole with toner, he locked or plastic by bolt or film in either event you first install the cassette on image prezhney. usually she is fixed in slots by thereby that after you will open the way a toner, he falls downwards. So tuba with toner is made thereby that under got up tuba хвостик film remains is sat and available to his(its) pash on itself and push off, this can be a plastic bolt or film. Not it is difficult her(its) find, besides, on box is always enclosed instruction or she there is beside you in documentation, usually drawings with methods place on inner face of the front lid. Do Not hurry, all easy. Good luck!
SOURCE: I am trying to install a new toner cartridge and
make sure all doors and covers are completely closed. toner bottle may not be in proper position
SOURCE: MFP sharp ar-m420u/mx-2300g new installation.
Change IC connector on toner unit with two screws neer gears of toner cartridge.
The toner cartridge is not installed, or the printer detects a toner cartridge error. The error is caused by a defective cartridge, an unsupported cartridge an invalid refill, or a cartridge meant to be used in another geographic region.
If the toner cartridge is not installed, install it. If the toner cartridge is installed, remove it and install a new toner cartridge.
For Cartridge errors, Press and release the right button twice briefly to display secondary error codes.
For further assistance, please contact Lexmark Technical Support.
