Delta Rockwell 34-450 10" Tilting Arbor Table Saw Unisaw 2 Hp Logo
B
Brad gilbert Posted on May 27, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Delta rockwell 34-450 10" unisaw very hard to raise and lower the saw blade
Les Davis
Level 2:
Sergeant:
  • Expert 247 Answers
  • Posted on May 28, 2014
Les Davis
Expert
Level 2:
Sergeant:
Answers
247
Questions
Helped
36562
Points
622
Clean & oil the gears.
1helpful
My unisaw will not start
if is Rockwell unisaw replace the brushes in motor. If a delta unisaw check motor ans starting capacitor. Best bet is to take motor to a motor repair shop
Nov 06, 2018 • Saws
Bladewillnot lower
sometimes when the blade is lowered too far the gears can get stuck. First try a reasonable tap with a mallet. If that fails you will need to access the mechanism, grease it and get it operating again
How much does a rockwell 14" band saw cost?
It has been discontinued by Delta. It would be hard to find replacement parts for this band saw. I think Rockwell 28-20C would cost $100-200.
Difficulty raising and lowering the blade on Delta rockwell10" unisaw 34-450
Ok, basic question...is the lock engaged? It is the small knob at the center of the adjustment wheel. Is it possible the screw has been galled?
Here is the manual- http://content.powermatic.com/manuals/1791227K_man.pdf
12" vintage Rockwell table saw Model# 34-388 I need a manual
Check vintagemachinery's website. You might be able to find some information there about your saw. Or make a quick google search , several threads will show up upon search that could help you. If you need band saw blades, I suggest you to visit sawblade.com .
I HAVE A DELTA BAND SAW SERIAL# 102-3033 AND NEED PARTS
Find time to check www.bandsawparts.com . or give them a call perhaps.
Looking for owners manuals for 2 saws
Your Delta radial arm saw (RS830) manual is here. Exploded diagram for parts, etc is here.
I'm not sure on the Rockwell, but here's a link to a manual for a Rockwell-Delta 10" Tilting Arbor Unisaw, circa 1969 which seems about right for a 34-466.
If that's not quite right, there a couple other manuals for old Rockwell saws here.
If this answer helped, please vote. Thanks!
May 19, 2010 • Delta Saws
Wood like to clean & update my rockwell model 14 band saw need a download of this saw
try there web sight, if I'm not mistaken, Delta bought out rockwell and they should be able to help. I had an old rockwell table saw and the man shaft that the blade attached to was missing.I contacted delta with the model number of the saw and they faxed me a blue print of the shaft and we machined a new one and the saw still works great.
Top Delta Rockwell Saws Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Delta Rockwell Saw Expert? Answer questions, earn points and help others
