Reset your electric breakers and make sure the door switch is working. If not sure on switch after resetting breaker turn dryer on and with open door press the door switch in .caution keeps hands from inside in case it starts to work It also could be a Senser inside of dryer that goes off if vent is plugged with debri
If you are having problems with your
gas dryer not heating the most common problem is that the ignitor
goes bad. Even though it glows sometimes it is still not working
properly.
if
you dryer is gas check out this gas
no heat
tip....
If you have an electric dryer, you can
have many different things that can go wrong causing the dryer not to
heat.
check
out this electric
no heat
tip...
heatman101
