Need to put belt back on
On most turntables you will lift off the platter (where the record sits) , place the belt around the underside of the platter, stretch the belt over the motor pulley as you gently lower the platter back into place.
If it is the original belt, chances are it will need replacement. The rubber material breaks down and looses it's elasticity. You can test this by stretching the belt out and seeing if it comes back to it's original size. If it stays larger or seems really easy to stretch, it's time for a new one. I have seen them on E-Bay listed for your specific model. Please advise if you need further assistance.
SOURCE: KM837 manual to fix belt on turntable
IF the belt fell off, it is likely that the belt is stretched and needs to be replaced. Use a couple of pencils to open up the belt and beasure the length. The belt should go around the two pencil erasures forming an oval. Use that measurement to determine the belt size and purchase a replacement belt. The belt will go around the platter and around the motor hub.
Dan
SOURCE: I need help replacing the belt on a 940 turntable.
it's simple the belt goes around the platter and the motor spindle thats it!
SOURCE: i have just a basic belt drive turntable and the
Hi There.
If the belt falls of the platter, it might be an indication that the belt has stretched and is now too large. Or maybe it just fell off for any other reason.
Remove the rubber mat, and pull upwards on the platter to remove it. Sometimes there is a small "C" clip on the center spindle that has to be removed first. (use a small flat screwdriver to remove)
Turn platter over, and put rubber belt around diameter ring on underside of platter. It should be snug, and not fall off when you turn platter over.
Put platter back onto turntable, and spin by hand until you see the motor shaft through one of the holes in platter.
With a pair of tweezers - or crochet hook, put belt over shaft.
You're done.
Put back rubber mat and give it a try.
Good luck,
Fred
PS: If there was a "C" clip, you can re-install it - or throw it away.
SOURCE: REPLACING TURNTABLE BELT
as the belt sliped from the turntable you must replace it with new one.if upside down turntable you can see marking of belt on it.just put a new belt on turntable keep it on center.remove top rubber pad you will see three or one big hole on turntable from where you can see the belt turn that hole so you can see motor pully just hold belt by a screwdriver and pull it on motor pully.
SOURCE: how do I replace the belt on my Realistic LAB-1500
Getting Started
For a Two-Piece Platter Turntable
For a One-Piece Platter Turntable
Realistic clarinette 105 model. Turntable not turning at all. Any suggestions na on possible causes.
