Frigidaire Ffhs2622mh 26 Cu. Ft. Side-by-side Refrigerator Ss, Black H Logo
l
lakeesha miles Posted on May 27, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where is the defrost relay button? - Frigidaire Ffhs2622mh 26 Cu. Ft. Side-by-side Refrigerator Ss, Black H
John Ray
Level 3:
  • Master 790 Answers
  • Posted on May 27, 2014
John Ray
Master
Level 3:
Answers
790
Questions
0
Helped
186470
Points
2180
Frigidaire equips most of its refrigerator models with automatic defrosting capabilities. This means that owners don't have to set a calendar reminder to manually defrost. The internal automatic defrost control and timing mechanism is placed at the bottom of most Frigidaire refrigerators, next to the stationary panwhere is the defrost relay button? - icon1.png that captures water - even the defrosted meltwater is automatically evaporated. You might be confused about how the defrost timer works, thinking it is broken. Frigidaire understood this might be an issue for some owners and suggests double-checking the defroster for normal operation because it may not be malfunctioning at all.
Read more: http://www.ehow.com/how_12165725_troubleshooting-frigidaire-defrost-timer.html#ixzz32x8RyDGe
Need manuel for a Kenmore frostless quick freezer model #253.9280410
I don't have a manual but these are fairly simple. On the back inside below is a defrost heater and terminator sorta like this:themobilian_747.jpg
The cold control maintains the temp and their is a timer that either puts it in run for 10 hours or defrost for 21 minutesthemobilian_748.jpgThe compressor relay goes out on these. The defrost heater or defrost heater termination themostat can cause defrost failure if bad.Not much to these babys.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
2answers
Everything has defrosted the lights are still on. and there is no no noise coming from the back of it now.
If this is a self defrosting unit, the defrost timer may be stuck in the defrost cycle. Or perhaps the cold control went bad, or even the compressor or starting relay burned out.
2helpful
My service man replaced the defrost cycle timer and the relay (timer was definitely broken, relay was highly suspect) but the freezer fan still has no power so freezer will not chill adequately despite...
Most all commercial freezers have a fan delay/ defrost terminator. It is usually mounted on the end of the evap coil. It's purpose is to sense the temp of the coil during the defrost cycle. When it hits a preset temp., usually around 55 degrees or more (depends on Mfg.) It terminates the defrost cycle. It also doubles as a fan delay. It allows the evap coil to cool off from the defrost cycle before allowing the fan to come on. Usually, the coil has to get around 20 degrees before fan will energize. I would look for this as a possible problem. It could be one device with 3 wires or 2 separate devices with 2 wires each. I've seen it both ways.
Hope this helps.
6helpful
6answers
I have a True Freezer Model T-49. It works fine but every 3 or 4
This sounds like a stuck relay to me. I have seen this problem before. The defrost clock kills power to the compressor relay coil during defrost. If the contacts in the relay are welded together the compressor runs while unit is trying to defrost. On newer units this relay is mounted in base of unit on the side or back of the electrical box near center bottom of unit. The compressor relay is a small rectangular box with 4 wires attached. It can be replaced with a single pole 20 amp contactor with a 120 volt coil/ or 240 volt. Check the units name plate voltage rating and ratings on old relay! ;)
Defrosting freezer
There is a relay on the front of compressor called PTC relay. If you heard a clicking repeatedly take the relay off and get a new one. You will need the model number of your unit. I like using the 3 in 1 relay lot cheaper and real easy to install. If you want to get with me and I can email you through it.
Nov 23, 2008 • Freezers
Cannot control internal temp plus clicking relay on control panel.
Where is the fast defrost button on Kenmore chest freezers?
Nov 20, 2007 • Freezers
2answers
Kenore freezer running constantly
need a model #.. is this a frost free freezer or a refrigerator ?
Sep 19, 2007 • Freezers
Top Frigidaire Freezers Experts
ZJ Limited
ZJ Limited
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
