Why does My dryer make a noise when it starts and stops? It also makes some sounds when it is running
The drum seems to be slipping or something. WHen I hand rotate it clockwise and stop it makes a bang like the wheels are catching up to it. like it slipped off the track or something.
Re: Why does My dryer make a noise when it starts and...
How long have you been using the dryer? seems to me you might have issue with the razor or the drive belt. you might want to get a professional to have a look at it.
I am guessing that it does not do anything after it makes the noise?. If you hear something running after the whirring noise, but the drum is not turning it is possible the belt has broken or slipped off the motor pully. If you hear no noise after the first startup and it completely stops making any sounds then it may be a motor problem. I am no pro, just a do it yourselfer. www.repairclinic.com can help ya more than me. Just have the model number ready when you go there and look at the symptoms. Hope this helps.
yes, it's called a blower wheel... it is what blows the air into the dryer to blow out the humidity through the vent... it has a D fitting and as you use it, the D rounds out and the 'squirrel cage' stops spinning and begins to slip... if you continue to use the dryer without replacing this, you could burn up your dryer motor... it will just over heat....
Prob. some failure of a bracket or loose inside... Have a local tecnician check it out. i think that ll be best cause i can't imagine that will be an easy fix.
during the process of moving your dryer, it sounds like the drum became dislodged. With the dryer off, open the door and try to move the drum by hand, if it sounds like something is 'dragging' them the drum is off its bearings. IF it is, the quickest way to get help to take it apart is go online to youtub, type in your dryers name and model number and ask how to replace drum
window.google_render_ad();There are many places & parts that could be causing your Whirlpool
dryer to be noisy.
To find out what is causing the noises, you
need to find out where are the noises coming from.
Start the dryer and let it run for a while and listen to try to
pinpoint where in the dryer the noises is coming from. Once you have
an idea of the area, you will need to disconnect the dryer from the
wall outlet and take the dryer apart.
Below you will find the parts that you need to check when your
dryer is noisy. The drum baffles:
The drum baffles are use to tumble the clothes inside of
the drum, in other words, the baffles job is to separate the pieces
of laundry as the drum turns.
When the dryer is getting older and if you use the dryer a lot,
the drum baffles holding screws will become loose. Loose drum
baffles will cause noises. All you need to do, is to open the top
panel and tighten the drum baffles holding screws.
The drum support rollers:
These dryers uses four drum support rollers, tow on the
front and two on the rear. The job of the drum support rollers is to
keep the drum tumbling smooth.
When the grease on one of the rollers dry out, the roller start
to make squeaking noises and the roller bearing will start to wear
out until the bearing on the roller is gone. When the bearing on the
roller is gone, the noise will change from squeaking to a clanking
noise.
The blower wheel:
The blower wheel is use to circulate the air inside of
the dryer drum. The most common Whirlpool blower noises are cause by
something falling inside of the blower housing and hitting the
blower when the motor runs.
The Idler pulley:
The Idler pulley is use to apply the necessary tension on
the belt. There are two types of idler pulleys, the pulley with the
wheel and the pulley with the teflon slide. A bad idler pulley could
cause a Whirlpool dryer to be noisy.
The drive motor:
Worn out bearings on the motor will cause the motor to
run kind of noisy. When the motor starts making noises, the solution
to this problem is to replace the motor.
The belt:
The belt on most dryers is only about1/4 inch wide. These
belts work very hard making the drum tumble. When the belt stretch
just 1/2 inch more that it supposed to, the belt will start slipping
and that could cause your Whirlpool dryer to be noisy.
As you could see, there are a lot of parts that could become
noisy in your dryer. When your dryer starts making noises, make sure
to check it out before it gets worse.
It is probably the rollers that the drum sits on. When these get old they loose their grease and start to seize up. They will start to make a terrible noise when this happens. They are cheap but kind of a pain to change out. They sit on the front of the drum and some models have them on the rear. In order to change them out you need to remove the drum. Let me know if you have any other questions and let me know if this was helpful to you. Good luck and I am glad that I could help.
Take off the back panel of the dryer and look at the motor and belt turning the drum. There may be something caught on the drum and is pinned in place causing the noise. The motor could be loose on the platform and needs to be tightened. It is probably something physical and seen causing the noise.
