Science & Laboratory Logo
l
leonardo palacios Posted on May 27, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How many grams of NaCl are present in 350 mL of 0.020 M NaCl solution? (Remember that 1 mole NaCl = 58.44 g/mole.)
Beowolf Jones
Level 2:
Habit-Forming:
New Friend:
  • Expert 79 Answers
  • Posted on Feb 13, 2015
Beowolf Jones
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
79
Questions
0
Helped
17831
Points
223
Grams = (350ml/1000ml )(58.44g/m)(.02m) = 0.40908 g.
How many ml is equal to 18mg
Depends what you are measuring. You need to repost with the material that you are measuring.
For example, 1 litre of water weighs 1 kilogram.
So, 1 litre of water weighs 1,000 grams.
Thus, 1,000 millilitres weighs 1,000 grams
So, 1 millilitre weighs 1 gram.
Thus, 18/1000 millilitres weighs 18/1000 grams.
I get 0.018 ml = 18 mg.
Good luck,
Paul
2answers
If I have 300 grams of milk how do you convert that into oz's
The metric system is easy in one aspect. 1 ml = 1 gram. If you are looking for liquid conversion you have 300 ml of liquid. 100 ml is 3.4 oz so you have about 10 oz of milk.
How to convert 80 ml to 80 mg
Hmm injection eh?
Well, 80 mg is not 80 ml, nowhere near.
For pure water 1 ml is 1 gram. So 80 ml is going to be 80 g which is 80 000 mg. This all comes form the base relation 1 litre (1000 ml) is 1 kg (1000 g).
For other substances, it will be a bit more or less than 1 gram in a ml, but not much.
It would help us both to know what is the injection, we are not the police.
2answers
WHAT IS THE DIFFERENCE BETWEEN MG AND ML
A Milligram is MG and a Milliliter is a ML. (MG) is used in dry measure and (ML) is used in liquid measure
1000 micrograms (mcg) EQUALS 1 milligram (mg)
1000 milligrams (mg) EQUALS 1 gram (g)
1000 grams (g) EQUALS 1 kilogram (kg)
1 kilogram (kg) EQUALS 2.2046 pounds
1 ounce EQUALS 28.35 grams
1 pound EQUALS 0.4536 kilograms
1 pound EQUALS 16 ounces
16 ounces EQUALS 453.6 grams
1000 milliliters (mL) EQUALS 1 liter (L)
1 liter (L) EQUALS 1.0567 quarts liquid
1 quart liquid EQUALS 0.9463 liter
4 quarts EQUALS 1 gallon
The molecular weight of NaCl is 58.44 grams/mole. If you had a 1.0 molar solution (1.0 M), you would have to put 58.44 g of salt in 1.0 liter of solutionHow many moles of NaCl would you have in 100 mL of...
1.0 LITER = 1000 ml so 100 ml = 0.10 Liter
or one tenth so you need to divide 58.44 by 10 with the result being
TA DA 5.844 gms (be sure you read the decimal points correctly. !
Clculate the amount of oxygen for the combusion of carbon 188gms calculate the mass of carbondioxied form?
This problem is the type often encountered in a first semester chemistry course, whether in high school or college.
It is very easy to solve if you already understand the following concepts, and if you also have had lots of practice applying them!
  • PROPORTIONS
  • THE MOLE
  • The LAW OF CONSERVATION
  • CHEMICAL EQUATIONS
  • BALANCED CHEMICAL EQUATIONS
  • STOICHIOMETRIC CALCULATIONS
  • SIGNIFICANT FIGURES, PRECISION, & ROUNDING OFF CALCULATED QUANTITIES
Initially, I will assume you already understand the above concepts, except for "stoichiometric calculations." I'd be happy to focus more on the other topics at another time, depending on interest, as indicated by posted questions.
To solve this problem you must be aware of the balanced chemical equation, as follows:
dubblea.jpg Notice that there is one C, one O2, and one CO2.
(For convenience in my post, I am writing the subscripts on the same line,)
"One what?" You might ask. It can be one "molecule" for each the O2 and CO2; and one "atom" of C. For the method of stoichiometry in this problem, we should use one "mole." So, there is one mole of C, one mole of O2, and one mole of CO2. In other words, the PROPORTION of these reactants (C and O2) and product (CO2), is one to one to one, also written one:one:one (or 1:1:1).
As I am assuming you know, these numbers are called the "coefficients" of the balanced chemical equation.
To calculate the mass in grams of O2 (the unknown quantity), we will need only the moles of O2 and the moles of one other substance from the balanced chemical equation. Since we are given the mass of C, we can use the moles of C.
TO WORK A STOICHIOMETRIC problem using a balanced chemical equation, YOU MUST INCLUDE THE MOLES OF TWO SUBSTANCES from the chemical equation in your calcuation, in this case, moles of C and moles of O2. As you know, you can calculate moles of C from the mass (in grams) of C that was given in this problem. You must calculate the moles of O2 by use of the following math expression:
mol O2 = (MOLE RATIO of O2 to C) x mol C.
(Notice that I have used the official abbreviation of moles, which is "mol".)
I will show you how to calculate the MOLE RATIO a moment.
Once you have caculated the moles of O2, you will have only one more calculation to do to calculate the number of grams of O2. Since I am assuming you already know how to calculate grams from moles, I will skip this step until my closing summary.
The MOLE RATIO can be calculated as follows:dubblea_2.jpg The calculated mole ratio will always equal the ratio of corresponding coefficients.
Notice that the mole ratio actually represents the ratio of the coefficients that are in the balanced chemical equation, and is written in the same order as are the calculated (calc'd) moles.
Therefore,
So, you can see that the number of moles of O2 = calculated moles of C.
The moles of C were calculated as follows:
The calculated moles of C = [grams C] / [MW of C] = [188 g C / 12.0 g] = 15.7 mol C
Therefore, there are 15.7 moles of O2, as calculated from use of the math expression (with boxes) shown above.
The wanted GRAMS of O2 are calculated from MW of O2 times its number of moles, as follows:
Grams of O2 = 32.0 g O2 x 15.7 mol O2 = 502 grams O2.
For your convenience as you make conversions among grams and moles, you may use the following memory aid: dubblea_5.jpg
To go from moles to grams, just notice that moles are beside MW, so multiplying them will give grams (moles x MW = grams). If you want to go from grams to moles, notice that grams are over MW, so (grams/MW) = moles. If you should want to calculate MW, you would divide grams by moles, (grams/moles) = MW.
One more tip: When doing calculations, use at least the same number of significant figures (sig figs) in the molecular weights (and atomic weights) as is in the given numerical data. That is, since there are three sig figs in 188 grams of C, use 12.0 as the atomic weight of C, and 44.0 as the MW of CO2. You would obtain the same answer using 12 and 44, but as you may know, following this rule would be more important in other problems in which the digit past the decimal is not zero. This allows proper rounding off of the final calculated quantity.
In Summary
  • Write the chemical equation, and balance it.
  • Use MOLES to do the necessary stoichiometric calculations. Convert grams to moles to make this possible.
  • Multiply the calculated moles of the given amount of chemical compound (or element) by the COEFFICIENT RATIO of the two compounds involved in the problem.
  • Convert moles to grams if grams are asked for by the problem.
  • Round off correctly.
  • Show the answer quantity, which should always show both numerical value AND unit.
Suggestion: Try out this method to other problems involving a chemical reaction. Good luck!
It is required to prepaire 100g of a 27.5% by mass solution of NaOH.calculate the nf of solution of NaOH.
I am going to assume your term, "nf," which I do not recognize as an acceptable unit of the metric system, is meant to be molarity (M). So, it seems to me that you are asking for the molarity of the solution that is indicated in the problem.
To calculate the molarity of the solution of NaOH in this problem, one must apply the ratio, moles per liter of solution, the definition of molarity (moles/L).
A 27.5% solution means (27.5 grams) / (100 grams of solution), which in this case is equivalent to
27.5 g / 100 mL solution, because the density of water is 1.00 g/mL.
Since 100 g solution is specified, that means there are 27.5 g of NaOH in the solution (100 mL volume, or 0.100 L).
Moles of NaOH in solution = [27.5 g NaOH / 40.0 g mol NaOH/ mol NaOH] = 0.688 mol NaOH.
Therefore, molarity of NaOH = mol NaOH / L = (0.688 mol NaOH / 0.100 L) = 6.88 M NaOH.
What is the difference between ml and grams. My
one is for measuring liquids (ml) and one is for measuring solids or dry materials (gms). A reference 237 ml is equal to 1 cup which should work for cottage cheese.
Mar 26, 2010 • Grilling
2helpful
In a 1.5% lidocaine solution, how many grams of lidocaine would be present in 10ml?
Hello, I can help you if you include more data in your question.
As an organic compound, lidocaine is insoluble in water, so I am assuming that either some combination of water and alcohol (ethanol), or a pure organic solvent like ethanol or diethyl ether is being used.
If lidocaine were soluble in water (which it's not), you would have been able to solve your problem as indicated below. Maybe you would be able to modify the indicated solution by taking into consideration the density of the organic solvent.
Percentage (%) by mass is one of the common ways to express the concentrations of solutions.
Since % means the number of grams of solute in 100 grams of solution (solute + solvent), a 1.5% solution of any solute refers to 1.5 grams of it in 100 grams of solution.
Assuming we are referring to an aqueous solution (that is, where water is the solvent), this reasonably approximates to 1.5 grams of lidocaine per 100 mL solution. We can assume this result, because we have a dilute watery solution, which probably has the density close to the density of pure water, which is 1.0 gram per 1.0 mL at commonly used temperatures, such as average room temperature.
So, 1.5 g lidocaine per 100 mL solution can easily be scaled down by one-tenth to give:
0.15 g lidocaine per 10 mL solution.
Top Science & Laboratory Experts
Collins Mccoy
Collins Mccoy
Don A
Don A
ADMIN Andrew
ADMIN Andrew
Are you a Science and Laboratory Expert? Answer questions, earn points and help others
