Where does it jam. Last time rollers where cleaned????
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: Problem in configuring IP address in Konica Minolta bizhub 210 Copier, Printer, Fax
Is there network card is installed in it, if yes then you can configure it with your network go to machine Manu in machine control panel and the in network settings here you can give the IP address and subnet mask after then reboot the machine.
If network card is no installed behind the machine then you can use its built-in USB or and parallel printer without NIC card.
SOURCE: konica Minolta bizhub 250 jammed but no paper
Please check the sensors and actuators ,open & close front door to reset nisfeed.Clarification Top feed = Automatic Document Feeder?If YES,please verify misfeed paper beetween coverplaten and feedbelt(Yellow).Is necessary disassembly the ADF.Good luck.You will find a little paper.
SOURCE: driver konica minolta 210 bizhub for type
Hi plujan,
As far as I am aware, the driver for this product is not available for the 64bit O/S.
I can only suggest trying the 32bit version.
You can find drivers here
http://m-press.uk.com/support.php
Click on Software and Drivers, then use the drop down menus.
Good luck
SOURCE: My copier is konica minolta bizhub 210 have
my konica minolta bizhub 210 shows paper jam after taking two or three copies continously...
