Black & Decker Spacemaker  10-Cup Coffee Maker Logo
A
Anonymous Posted on May 27, 2014
How do I find a new Black & Decker space maker coffee maker #ODC300
The container that you pot the water in to run it through the coffer leaks
Steve
Level 1:
  • Contributor 29 Answers
  • Posted on Jul 27, 2014
 Steve
Contributor
Level 1:
Answers
29
Questions
Helped
7651
Points
43
Look for a replacement used ODC300 water reservoir on eBay.
5 Related Answers
Jack Reed
  • 30 Answers
  • Posted on Mar 29, 2008
SOURCE: Black & Decker Spacemaker ODC325 Coffee Maker
You can find them on ebay from time to time. One went for $25 last week and there's one there now for $50, which is steep for a used unit, but if that's all that will fit then it's worth the price. A reviewer on another site suggested second hand stores as being a good source for these as well. Good luck!
Anonymous
  • 350 Answers
  • Posted on Jan 19, 2009
SOURCE: Need a replacement carafe for the Cafe Noir coffee pot.
I've replaced my coffee pot from my local Ace Hardware!
I'd call first!
Good Luck!
co7196
Ned C Cook
  • 3433 Answers
  • Posted on Jun 22, 2009
SOURCE: filter cone is full of hot water & thermo pot has about 5 - 6 cup
Te water fill lid is not closed or or the flow valve in the tank is plugged. Remove the basket and clear the hole in the bottom of it.. If new, return it to place of purchase.
Steve
  • 47 Answers
  • Posted on Jun 11, 2011
SOURCE: Hi My Black & decker Space
Try this solution. It should fix your problem.
Steve
  • 47 Answers
SOURCE: my black and decker 12 cup coffee pot quit perking
Try this solution. It should work for you.
Altrev
My coffer maker brew basket keeps overflowing. I've deduced that when I push my decanter into the machine, there is so much give that the plastic arm in back pushes it forward and stops the coffee from...
Hello, Srober48 -
Since your Black & Decker coffee maker is only a few months old, it is most likely still covered by warranty.
I suggest you call the Black & Decker Customer Service / Support telephone number printed in your owner's manual / instructions and find out if you can take the coffee maker to an authorized repair center (for free, warranty-covered repair) or if the company will provide you with a replacement coffee maker.
Note: I suggest you do not try to repair the coffee maker yourself while it is still covered by the warranty.
Best wishes.
2helpful
Leaking black and decker under counter coffee pot
the 90 degree red elbow has worn away of hot water temps and will leak some but all hot water to the bottom of machine. needs to be replaced or retrofit one
Filter cone is full of hot water & thermo pot has about 5 - 6 cup
1helpful
I'd call first!
Good Luck!
Water reservior spills the water trying to push button to put in also the light is not working i got it for xmas modelodc440white do i have adefective pot? not satisfied with it i loved the old space
Try contacting your warranty service at Black and Decker if your machine is under warranty. If you don't know then you should be able to call and find out. I don't have the number for them but a quick internet search should find it or if you have your user manual then all information should be inside.
Coffeediva22
Top Black & Decker Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Black & Decker Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
