SOURCE: toshiba 32a41 has power, no pic or sound
Check power supply with service literature,esp.relay circuit
first, then all other B+ voltages. Solder any / all bad solder
connects,esp. regulator pins........
SOURCE: TV Remote for Toshiba 32A41 does not work
YOU SOUND LIKE THE REMOTE SENSOR BAD IF YOU CLEAN THE SCREEN WITH WINDEX IT HAS GOT ON THE SENSOR THE SENSOR HAS 3 LEGGS
Testimonial: "Windex seems to have done the trick! Thanks!"
SOURCE: Toshiba 32A41 Set comes on goes into shutdown
dear sir it is problem cercuit dry solduring
horizental output is demage. please over all resoldering and change transistor
Programming the Sleep Timer:
