SOURCE: Sony Trinitron KV-27S46
There is a problem in the sweep section of the set. The Horizontal sweep power supply most likly. there is nothing a layman can do as it will involve troubleshooting the solid state circuit. please find a trainded tech to assist you in this repair.
SOURCE: TV is out
I was advised the same - the power supply needs to be rebuilt - Sony parts only or else it doesn't last. Cost runs between $150 and $275 (Cdn)
SOURCE: Sony FD Trinitron WEGA..won't turn back on
Please post the blink count. The standby light should be blinking a repeated count. That will indicate the circuit where the problem resides.
Thanks,
Dan
SOURCE: Sony Trinitron Color TV KV-35V65 - No Picture, red light stand/by timer flashing
A reset won't fix this. The standby light should be blinking a repeated count with a 3 second pause inbetween. Post that count here. That will indicate the circuit/condition that is preventing the set from turning on.
Thanks,
Dan
SOURCE: TV went OFF
The standby light should be blinking in a repeated pattern. Count the blinks and report that number here. This will indicate the circuit that is defective and will allow us to provide a repair suggestion.
Thanks,
Dan
