No cannot over ride set at large doe the machine fill to a certain level then stop if so operating correctly if it never stops filling with water then there is a leak in the fill system either a hole in pressure switch hose it popped off tub or water leaking out thru drain system pump or siphoning thru hose again if unit starts to agitate there is enough water in unit per design
The water level is controlled by a pressure switch connected to a long rubber hose that goes inside the tub. If the switch is defective or if the pressure hose is blocked the machine may under-fill.
Check also inlet hose and water pressure from the house.
Front load washing machines are better than top load money wise.
One advantage of a front
loading washingmachine is an increased
capacity. Since there is no central agitator, the horizontally-oriented
drum can hold at least 20 to 30% more clothing per load. For a large
family, this could mean running only three loads in a front loading washingmachine compared to five
in a top loader. Fewer loads
often translates to savings in utility bills and water usage.
Another advantage of a front
loading washingmachine is less water and
detergent usage. A top
loading washer must use enough water to cover the highest level of the
clothes. A front loading washingmachine, on the other
hand, only uses enough water to cover approximately the lower third of
the tub at most.
A- Two things could be your problem... 1) - sometimes the screens in the fill valve or inside the ends of the fill hose get clogged up...use a tooth brush to clean them out. Don't forget to shut off the water first before removing the hoses to check for this. 2) - The fill valve itself may not be opening fully = time for a new fill valve.
Be sure you are using HE detergent and only about 1 Tablespoon for a load. You are ending up with too many bubbles in the machine and when it goes to spin the bubbles come out the air vent. There is a valve that closes during spin but bubbles are not strong enough to lift the valve it has to be water hitting it before it closes.
