Just replaced green bulb
SOURCE: Red stand by light blinking
5 blinks = lamp driver (ballast) failure.
1-468-798-14 for the 610 model
replacement is done from the back of the set, should be straight forward, keep the red ballast wires apart for best results
if a tech replaced the red tube, you have an older tv where 5 blinks is the AKB error meaning your CRTs are getting old.
SOURCE: kdf-60xbr950 - red light blinks 3 times for a minute and tv turns off
same problem as others 3 blinking green lights then orangey colors then 3 red blinking lights afterwards shuts down fan runs for about 2 mins solution check your door cover for warpage or deformed just a bit under set screw there is a push in switch try and push it in with q tip while holding turn on tv if it works then that door is deformed and defective change it
thanks for solving my issue tv works again very helpfull thanks
SOURCE: 10 BlINKING LIGHTS ON SONY TELEVISION
in these sets you have to check the power supply board. check all capacitors maybe blown on top.
SOURCE: power light flashed red 4 times then repeats no pic,new bulb/fan!
Check the fan that cools the bulb. It is directly behing the bulb. It should turn on when the power comes on. It apparently has a safety to protect your tv(and home). mine is in the process of going out. looking for online solutions as we speak.
SOURCE: My SXRD 60
Perhaps it needs the bulb, but there is also a good possibility that the lamp fan is getting clogged and shutting down the set. This is NOT the fan you see in the back, instead, it is above the lamp, and is a small blower-type fan, that tends to clog with dust. You CAN check this, when you open the lamp door,you can see the blower wheel, and if it is all dusty, it needs to be cleaned out--but do NOT just blow it out, or you might clog the engine!! It needs to be removed, and cleaned out of the set.
But first...if the blower is not too dirty...try another lamp.
