SOURCE: my Biggs and stratton446777 rockers dont move as it spins over
you my have a broken rod pull spark plugs out and see if pistons are moving,if so check for bent push rods,if push rods aren't bent then you may have bad cam
SOURCE: Changing oil in Biggs and Stratton engine
Use 10W30 weight oil. The capacity is 1.5 Quarts (48 ounces) with filter change. I highly recommend you use 100% synthetic oil in an air cooled engine. Change the oil and filter every 50 hours of use.
