How to solve this problem dell inspiron n 4010 2 beeps code
SOURCE: loud beeps at start up dell inspiron mini
Beep codes for the Inspiron Mini are as follows:
Beep Code Possible Problem
One Possible system board failure — BIOS ROM checksum failure
Two No RAM detected
NOTE: If you installed or replaced the memory module, ensure that the memory module is seated properly.
Three Possible system board failure — Chipset error
Four RAM read/write failure
Five Real Time Clock failure
Six Video card or chip failure
Seven Processor failure
Eight Display failure
SOURCE: dell inspiron N 4010 laptop
Hello there,
You can click on the link below:
http://search.dell.com/results.aspx?c=us&l=en&s=biz&cat=sup&cs=555&k=dell+inspiron+n4010&rpp=12&p=1&subcat=dyd&rf=all&nk=f&sort=K&ira=False&spf=Inspiron&~srd=False&ipsys=False&advsrch=False&~ck=anav
Hope this helps.
SOURCE: Dell Inspiron 4010 Laptop boot
Hi
it may be worth turning off the laptop and removing the hard drive
then restart the laptop
then turn off again
put hard drive back in
and see if this helps
also when turning on try pressing the F8 switch which hopefully will take you into the repair option
and choose either the last know good configuration or the repair my computer option
hope this will help you
many thanks
SOURCE: dell inspiron beep codes
These are the Dell beep codes.
DELL BEEP CODES
Beep Codes Beep Code Description Failure Coverage 1 System Board: BIOS ROM failure System Board, covers BIOS corruption or ROM error 2 Memory No Memory / RAM detected 3 Chipset Error (North and South Bridge Chipset DMA/IMR/ Timer Error for Intel platform); Chipset Error System Board Chipset Failure Time-Of-Day Clock test failure. Gate A20 failure Super I/O chip failure Keyboard controller test failure. 4 RAM Read/Write failure Memory failure 5 RTC Power Fail. CMOS battery failure 6 Video BIOS Test Failure Video card / chip failure 7 CPU Cache Test Failure CPU failure 8 LCD LCD failure
