Wont work at all no power no error code
I have a hotpont aqualtis and it had dtopped working and theres no power to it i change the fuse and still nothing emall me at [email protected] thats
If the machine is dead, I would check the cable from the main boad leading to the front display on the door. Often the cableharness breaks at the hinge. (one of cables). If that is not the case, eather the main board or display board is dead.
SOURCE: on a hotpoint aqualtis aqxx149pm i get error code f8 flashing
Hi.
F8 means that heater relay cannot be activated, you need to call an engineer.
Could be expensive, possibly a new control board needed
SOURCE: Hotpoint Aqualtis LCD display language
Follow this link and read where to find your model # and insert it in the box. I hope this helps. http://genet.geappliances.com/DocSearch/Dispatcher?REQUEST=SEARCHWITHURLCONNECTION
SOURCE: Hotpoint Aqualtis AQGF 149 Error F-05 what does this mean?
F-05 means service switch jammed.
Hope this helps. =)
SOURCE: I have a Hotpoint Aqualtis washing machine. It is not working
Check if the waste pipe isnt blocked.
SOURCE: washing machine door wont open on hotpoint
remove the front kick strip, on the LHS you will notice a yellow tag. with the power on on the machine pull down twice gently on this tab. this should unlock the door.
if you now notice the drum is full of water its more than likely your filter is blocked and this is what caused the door not to open.
