SOURCE: Drive belt diagram
go to sears.com and put in model# for parts look up and they will have it or call 1-800-4my home to get owner manual
SOURCE: bought a new husqvarna 46 inch cut mower today
With the mower off reach under the deck and wiggle the blades up and down. If you have a lot of play you will need to replace the bearings. Make sure if you replace the bearings have them pressed on. Using a hammer and beating them on can cause damage to the mandrel and then it gets to be expensive to fix.
Good luck. Let me know if this helps you out.
roundo4
SOURCE: what size and how many blades do I need for my
Well I guess laying down next to it and taking a look under the mower deck is beyond the question. One could ask about how many teeth the horse has or just look in its mouth. However, I am going to guess 3 blades as 2 blade units usually are 42" cut maximum. Mine is 48" and has 3 blades.
