Sewing Machines Logo
A
Adriana Dugo Posted on May 26, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kenmore ultra stitch 6 Model 13402
When I turn the knob selector from straight to zig-zag it doesn't make the zig-zag it stays straight. Do you know why?
ken dourof
Level 3:
  • Master 980 Answers
  • Posted on May 27, 2014
ken dourof
Master
Level 3:
Answers
980
Questions
0
Helped
264458
Points
1919
If the machine is not zig zagging when you select zig zag it will mean the selector finger needs adjusting which is a shop job
2 Related Answers
Debbi's Sewing Machine Repair
  • 7365 Answers
  • Posted on Sep 17, 2012
SOURCE: zig zag stitch doesn't work
the machine needs to be checked, something could be wrong
with a gear or the dial.
  • 7365 Answers
  • Posted on Nov 16, 2012
SOURCE: stitch selector knob turns but doesnt change stitch from a straight stitch on kenmore ultra stitch eight, model 13453
when a part on the sewing machine does not respond like it's suppose to ,,then it would be a good idea to have the sewing machine checked
1helpful
Zig zag stitch doesn't work
Trouble sewing lycra fabric using a zig zag stitch
You have the machine set for blind hem stitching. Change the stitch selector to stretch stitch, which is a single, in line stitching zig zag stitch.
Cheers,
Embroidery Services
San Diego, CA
1helpful
The 6 built-in stitches (such as blind stitch, darning stitch, etc.) are not working, they only just do the basic zig zag stitch. Also the cams for decorative stitching do not work either. These are all...
I have the same model, have you turned the first knob on left, the stitch selector, to the stitch you want? Then turn the middle knob, the stitch width to "4". Use the colour guide marks shown in the little picture on left of the knobs so you are dialing up the right settings. So for the zig zag, elastic blind hem, scallop, overcasting and multi-stretch stiches, 1-6 on the diagram you'll be setting the left knob to 1, 2, 3, 4, 5 and 6 respectively and the stitch width and length knobs to "green", you can vary the length and width to suit what you want.
Then for the cams, you need to set everything zero, turn stitch selector to 7, the cam setting. then turn the width to orange again (3-4) and the stitch lenth selector to the orange setting, right around the knob. This engages the "Elnagraph" the device under the flap on top of the machine to read the discs. Basically the green stitches the needle is swinging from side to side while the feed dogs move the fabric forward, making your zig zags, blind hems etc.
But when you engage the Elna graph, the machine matches stiches by moving the fabric "forward and backwards at certain times, while the needle does its thing from side to side. This is what makes elastic or stretchy type stitches because you are putting "stretch" into the seam by sewing forwards and backwards.
Please note: always turn your stitch width and length back to Zero BEFORE you make any changes to the left knob and select a new stitch as this saves on wear and tear to the moving parts in these wonderful machines.
I do hope this assists you and I haven't just told you stuff you already knew!
1helpful
My Elna SU will only do straight stitching it will not zig zag
Do not know how to position the needle so it is in the center position? Where do I do it?
Turn the lower knob on the right hand side of your sewing machine. This is the control for the stitch selector (like zig-zag, buttonhole, etc.). You will see 3 straight stitch settings. One is for left, one for center, and one for right. Align the orange indicator with the center line & voila.
Only does zig zag stitches, no straight stitches,
make sure the pattern selector is set for straight stitch first. If it is set correct then the machine may be "stuck" is zig zag mode. May need to be de greased and then re lubricated.
3answers
Kenmore 1914 Zig Zag needle wont move side to side
Maybe a stupid question, but do you have the width selector to it's widest setting?
3helpful
How do I do a stretch stitch?
The bes way to hem a t-shirt on a household machine is to use a double needle, straight stitch. You will see two straight stitches on top and zig zag on the back. Just make sure the zig zag catched the top of the hem.
Top Sewing Machines Experts
SmartAviator
SmartAviator
Are you a Sewing Machine Expert? Answer questions, earn points and help others
