How do I change the fuses? I have no lights or any signs of it being on.
Is the outlet live? Does something else plugged into the same outlet work?
Does the receiver have a master power switch on the back that may have been switched off by accident.
Some - not all receivers have user replaceable fuses. If you do not see a fuse holder on the receiver near where the power cord attaches then you may need to open the chassis to see if there are replaceable fuses on the power supply board inside. Follow where the power cord connects to the chassis. It will lead to a board with a transformer that changes high voltage to the low voltage that the receiver needs to operate.
IF there are user replaceable fuses inside they will be on the power supply board.
PLEASE make sure that the unit is unplugged and has been for some time as the transformers sometimes stores residual voltage that will harm you. Don't do this unless you know what you are doing inside the unit. I recommend novices just take it to the repair center.
Also - IF you replace with the wrong fuse type and rating you can cause further damage to your unit.
Good luck and be careful.
