Tray that catches the drips inside fridge to keep water out
SOURCE: Dometic Top Freezer RV/TT Refrigerator
You have a switch inside the door. Turn it on this actually keeps the light on inside. This may help with your humidity problem. Also check to make sure the drain out side of the coach is not clogged you should see water coming out
SOURCE: Dometic rv fridge runs fine on elec, lights on gas
It is key that all control switches are in the correct position, depending on what power source you are using, gas, electric, etc. If the switches are not in the proper setting, the unit will not operate.
Here's the manual for your fridge that should be printed out for your use and reference (and reading enjoyment). It has all the info needed to operate and troubleshoot it.
Typically, when using any gas appliance with a pilot light, the sensor has to first be hot enough to trigger it to allow the safety gas shutoff to open and allow the gas to flow to the pilot/burner. Follow the instructions and you should be all set.
http://gasrefrigeration.net/dom_techdata/2707_2811SM.PDF
Hope you find this helpful and best regards!
SOURCE: Have dometic fridge in rv.......new in 2007 all
Check your 12 volt ground
Check the fuses in the back under the cover
Other than that sound to be a bad control board
SOURCE: our rv has a dometic rm2600 fridge that smells of
Sorry to give you the bad news. The ammonia smell is the the refrigerant
leaking out. Dometic uses ammonia that is heated and then condensed to cool. It will all leak out and quit cooling.
The fridge is wrecked. There are shops that rebuild the units. Beings as ammonia is corrosive one must assume there may be other leaks ready to appear. There are RV salvage yards that sell good used units.
Again Sorry for your loss.
SOURCE: We just aquired a 1995 RV with a Silhouette
Should be a moedl number.RM -----# on fridge. Have that ready and go to: (www.dometicusa.com) . Click on customer support, then on left side you'll see Operation and installation manuals, click on that. Click refrigerators, for Caravans, motorhomes, RV's, and find your model and download PDF for copy of manual.
