IPad does not recognize the device. Is it even possible to pair?
SOURCE: Unable to set pairing between jabra bt 125 and bluetooth device
You simply need to hold the button down for a long time, it will flicker blue at first, don't let go of the button, and it'll turn blue for pairing.
SOURCE: cannot pair Nokia N70 to Jabra BT150 bluetooth headset
turn on cell phone. activate bluetooth. press right button to search for bluetooth devices. Then press the on button and the volume UP button at the same time on the Jabra headset. The cell phone then finds the device. put in the password/pin (usually 0000). and voila! it works
SOURCE: Need to re-pair bluetooth to phone
Go to ur phones bluetooth settings - activate pair new device - at the same time press and hold the on button on your blue tooth head set for about 10-15 seconds - this will enter the device into pair mode - on your phone - click on pair with new device etc etc, the default access code is either 0000 or 1234
SOURCE: I cannot get my Blackberry Storm to pair with my Jabra BT2070.
You have to first put the Headset into discoverable mode. According to the Jabra website, this is done by pressing and holding the end/mute button until the light comes on steady. Follow the procedure for your phone to pair a bluetooth device to it. The PIN code will be 0000.
SOURCE: how do i pair a jabra bluetooth with ps3
Refer here:
http://www.fixya.com/TipsAndTricks/preview.aspx?thid=5009279
Among the convenient features of the Apple iPad is the ability to pair the iPad with Bluetooth devices.
Bluetooth devices allow the iPad to interact with wireless accessories including headsets and keyboards.
Like most things related to the iPad, connecting an iPad to a Bluetooth device a quick process.
Refer to the device's instruction manual for directions to make the Bluetooth device discoverable.
Typically, this involves holding down a button for a few seconds.
To pair an iPad and a Bluetooth device, the Bluetooth device must be discoverable.
Turn the iPad's Bluetooth capability on.
Go to the settings menu on the iPad by tapping the "Settings" icon on the iPad home screen.
Tap "General" from the left panel and then "Bluetooth."
Once you are in the Bluetooth screen, slide the "On/Off" switch to "On" to turn on Bluetooth.
Select the device you wish to pair with the iPad from the list of discoverable Bluetooth devices that appears on the screen.
Depending on the device, a password may be required.
Refer to the Bluetooth device's product manual for this password.
Hope this helps.
