Did you clear the counters first, then did you run the required procedures afterwards? when you say background are you talking about a previous image? if so it the fuser
Take out the toner cartridge and tap it on it's end to dislodge any packed up toner first. If this doesn't work and a new toner cartridge has no effect, then the high voltage applied to the drum is not attracting the toner powder. That will take a repair service to fix the printer.
IF YOUR USING A BIZHUB 421 DRIVER FOR A MAGICOLOR 2550, THAT ITS YOUR PROBLEM YOU NEED TO GO TO
onyxweb.mykonicaminolta.com/OneStopProductSupport?appMode=Public
SELLECT MAGICOLOLOR PRINTERS 2550
WHEN EVER I TRY TO PUT THE FULL LINK, IT WONT LET ME POST, BUT I YOU PROBABLY KNOW WHAT TO PUT ON THE FRONT OF THE LINK
Maybe the power it's not correct.Try to reset hold utility key and power on hold the utility and on screen will be show the ikon trouble reset push it and will show ok power of and on again
D-203 can be caused by dry scanner rails, remove the original glass and clean and then oil the scanner rails on both sides. Also sometimes your CF card cab be corrupted. A C-2403 is a dirty toner bottle detection sensor, remove the toner bottle and clean inside the housing, the sensor is way at the back on the top left side.
