SOURCE: I am unable to change the time on my phone to reflect the day time savings
You will need to enter programming mode. Here are the directions.
You must be on the main phone on jack 01 to set time. You can determine if your phone is jack 01 by setting the switch on the end of a display phone to PROGRAM and then pushing the number 6 on the dial pad. The phone will read the jack and extension number. When you have determined the jack 01 phone, do the following.
SOURCE: advanced hybrid system panasonic kx-t7730
how do i change my voice message on my answering machine??
SOURCE: How can I change the date and time on a Panasonic KX-T7730
From the phone connected to Jack 01 (usually 101) press PROGRAM *#1234 and dial 000 and the SP PHONE button. Your display should show a blinking cursor over the year. Use the FWD and CONF buttons to go forward (and back) and the AUTO ANS or keypad to change the entries. Finish by pressing STORE
Carl
SOURCE: I NEED TO STORE NUMBER ON MY PANASONIC KX T7730
The mechanics of storing a speed dial number on Panasonic phones is the same, even if the phone can be connected to one of 18 different model Key Service Units. It involves pressing PROGRAM a button, an access code, the number, and STORE. In the U.S. our access code to get an outside line is "9". You may be using something different, like '0'.
The differences are if you can dial "9" on the intercom and get a dial tone, which collumn of buttons you press, and/or whether you want this to be PERSONAL numbers or SYSTEM numbers.
In a TA-824, lines are accessed high to low. If you have 2 lines on a basic system and dial "9" to get an outside line, you will land on line 3 if you have not told the system that line 3 is disabled (system program 400). So, the fast answer is press PROGRAM, a button on the right side, dial 9+your desired number and STORE. If it's a left side button, dial 29 instead of 9.
System speed dials requrie access to system program 001.
If this does not work on your system, please comment back with your actual system model number.
Carl
SOURCE: I need help setting speed dials on a Panasonic KX-T7730!!
Hello, from the Switcboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the cradle press Program * # followed by the system password ( default is 1234). Now press 001 and then SP-PHONE. Enter the system speeddial location ( 00 to 99 ) or just press SP-PHONE again to go to 00. Now enter your line access number ( usually 0 or 9 ) followed by the telephone number you would like to assign for the speeddial. Now press AUTO DIAL / STORE to save your setting. To go to the next speeddial location press SP-PHONE and follow the above steps again. Press Program to exit program mode. To dial the system speeddial from any extesion lift the handset and press * followed by the speeddial location ( example 00 )
PLEASE rate this answer if it was helpful.
Thank you.
