If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electro-medical.blogspot.com/ http://electronicshelponline.blogspot.com/
Search the site by type in the "Brand Name" (Exclude the model number) to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
go to start menu, find the search bar and type in screen saver. If that does not work then go to control panel, Personalization or display and find screen saver. There you can adjust the time when it will kick on.
Y-Sustain should be suspected. Make sure before replace it. If you wish to get more details, check the site linked
below. Pull up older posts there. Check
the site with patience, as it has over 2400 posts now. All are related to electronic equipment
repair help. If you search the site in
Timeslide option, which can be selected from the drop down list at the top left
of the display window, it will be easy to locate the related post. You can also do a search by type in the
brand name to your device into its search box at the top right of display
window.http://electronicshelponline.blogspot.com/
I have the SAME issue and so far it seems to be an issue with the fan not kicking on.... I turn it on in the morning, as soon as you hear sound the red lights kick on and I shut it off... it takes a few seconds to shut down so stay close to your remote durring this process and as soon as the "red light" kicks in, turn it off, as soon as it's off, turn it back on... I have to go thru this about 30 times now before I can get the picture to stay on, but it eventually kicks in. Hope this helps!
Don't feel bad - these are cheap TV's and there are lots of problems
with them. Just be glad it failed so soon that you can take it
right back and get something more name brand this time.
Remember - always google the model number you are looking to buy (with
either "repair" or "complaint" in the search) and you'll be less likely
to buy an TV industry land mine.
