Question about KitchenAid K45SS Classic Stand Mixer
Where is the Height Adjustment Screw on the KitchenAid K45SS Classic Stand Mixer? rcherbig0417@gmail.com
  • KitchenAid Master
  • 1,341 Answers
It is in the front middle of the hinge area, visible with head raised. Clockwise to lower and anti clockwise to raise. Head height is set with flat paddle to just clear the bottom of the bowl when head is locked down.
Posted on Dec 18, 2014
SOURCE:
SOURCE: kitchenaid mixer k45ss slow gear
If you look into the brush holder you will see a stopper at the botom ,(this is so when brushes are wore the spring is not driven into armature) .. the brushes have to be inserted so the groove is lined up , try that
Posted on Apr 07, 2008
SOURCE: KitchenAid K45SS Mixer Service Manual
http://downloads.mendingshed.com/KitchenAid_Service_Manual.pdf here is a Service manual that gives good breakdown & repair in English with B & W photos. Can anyone who does a full download on this (16.2 mb, 32 pgs) please email me a copy. I only have dial up & connection does not stay up long enough to do a full download. Email : jesseddieus@yahoo.com or jesseddieus2000@yahoo.com . It would be greatly appreciated. Thanks & have a great day.
Jim
Posted on Nov 29, 2008
  • 118 Answers
SOURCE: Repair manual for a KitchenAid K45SS stand mixer
You should be able to look up your manuals HERE
Posted on Nov 30, 2008
hslincoln
  • 235 Answers
SOURCE: k45ss kitchenaid stand mixer, i took out the brushes
jrichards - I hate it when that happens! It seems that power is not getting to the armature from the brushes so I would suspect that one or both of the brushes is (are) not seated properly. Did you remove the brushes to replace them or were you just inspecting them? I'd suggest removing them again and making sure the contacts are facing in the right direction to contact the armature. The concave contact face should be resting completely on the armature. If you've turned it 90 degrees too much, it wont' seat properly. I hope this helps... Howard, Burke, VA
Posted on Nov 03, 2009
  • 111 Answers
SOURCE: KitchenAid Artisan KSM150BOB Stand Mixer won't start
It could be very easy. It maybe you have a the brush in the wrong way round or they have simply run out. They are on the sides under the black plastic caps. Although they will fit in the hole any one of 4 ways round, there is a key on one corner which means it will only go in one direction. Use a torch to look into the hole before you put it back in.
They shoud look like this : brush
Posted on Jan 24, 2010
How can I adjust bowl depth?
KitchenAid K5SS Heavy Duty Commercial Stand Mixer ...
www.fixya.com/...kitchenaid...k5ss_heavy_duty/adjust_beater_height
KitchenAid K5SS Heavy Duty Commercial Stand Mixer, adjust beater height related issues. Get free ... Beater hits bowl beater height adjustment screw does not fix problem ... beater ... ...adjust beater depth-it is scraping the bottom of the bowl.
KitchenAid K5SS Heavy Duty Commercial Stand Mixer Adjust
www.fixya.com/search/p105880-kitchenaid...k5ss_heavy_duty/adjust
KitchenAid K5SS Heavy Duty Commercial Stand Mixer, adjust related issues. Get free help ... How can I adjust beater to bowl clearance on my Kitchenaid mixer? I have a kitchen ... How do I adjust the depth of the dough hook. how do I adjust ...
How To Adjust the Bowl Height of Your Stand Mixer ' The ...
www.thekitchn.com/how-to-adjust-the-...
Apartment Therapy's The KitchnFeb 10, 2011 - In the world of stand mixers, there's two different types. ... It's easier than you think and will make your appliance last longer and food taste better! ... If yourbowl height is too high, you'll hear the adjustment needing to be made before you ... I have a different issue with my KitchenAid Artisan mixer (tilt head).
Dec 25, 2015 | KitchenAid K5SS Heavy Duty Commercial...
Why ceramic is wearing off beater of kitchenaid mixer?
You need to adjust the head height. Raise the head and look into the hinge from the front of the machine. There is a single slotted screw there, anti clockwise to raise the beater from rubbing the bowl. Just enough to clear is all you need.
Jul 20, 2014 | KitchenAid K45SS Classic Stand Mixer
How to fix my kitchenaid mixer hit bowl?
The height of the beater to the bowl is adujsted by the screw found when you tilt the head back.
Service Manual:
http://www.kitchenaidparts.eu/documents/pdf/service-manual/classic-svc-manual-new-email-version.pdf
May 26, 2014 | KitchenAid K45SS Classic Stand Mixer
Kitchenaid mixer K45SS only has one speed, slow. Have taken apart and regreased the machine. I plugged it in while the planetary head was off and it went through the speeds as normal, but as soon as
Did you clean the are around the variable-speed control lever?
Please be sure to unplug the mixer BEFORE disassembling the mixer.
http://www.ereplacementparts.com/kitchenaid-k45sswh0-classic-stand-mixer-parts-c-114958_114959_115060.html?page=4
http://www.ereplacementparts.com/article/11983/How_to_Replace_the_Speed_Sensor_and_Control_Board_on_a_KitchenAid_Pro_6_Mixer.html
Jan 07, 2014 | KitchenAid K45SS Classic Stand Mixer
Beater is rubbing the bottom of the bowl. How do i adjust the height
Tilt the mixer up, look at the joint where it connects to the stand under the "belly" of the mixer. You should see a small silver screw. Dialing it out will raise the head of the mixer, dialing it in will lower it.
May 02, 2011 | KitchenAid K45SS Classic Stand Mixer
My kitchenaid mixer seems to have dropped down to low in the bowl
Tip the mixer up and look for a screw on the hinge underneath the top part. Turn this screw counterclockwise about 2 turns and the paddle will clear the bototm of the bowl.
Feb 01, 2011 | KitchenAid K45SS Classic Stand Mixer
Bearings in the lifting head are worn out. the top won't lock down & the paddles are rubbing
I think what has happened is the head's position has dropped over time. If you left the head up there is an adjustment screw on the hinge visible from the front. This altered the height of the head when you lower it back down. Adjust it so the paddles no longer hit the bowl. Hopefully this will also fix the problem with your head locking into position as well.
Jan 25, 2010 | KitchenAid K45SS Classic Stand Mixer
Stand jumps
The height of the beater is easy to adjust on the tilt-head model.  Tilt the head back, and look into the pivot from the front of the mixer.  You should see a screw on the hinge.  With a flat blade screwdriver, rotate this screw half a turn counter-clockwise to raise the beater height.  Lower the head and check that the beater does not touch the bowl.  Repeat until the adjustment is satisfactory.  To lower the beater closer to the bowl, turn the screw clockwise instead.
Jan 12, 2009 | KitchenAid K45SS Classic Stand Mixer
Beater is too low in mixing bowl. How do you adjust the height of the mixing head. There is a screw in the pivot, but it does not turn. Does this adjust the height?
The adjustment screw did work for me but I adjusted using the dough mixer instead of Flat Head mixer as specified (only-realized after reading the manual ;o).
After readjusting using the correct flat head, everything is happy again.
- manual, I don't need a stinking manual !!! ;o)
Jan 05, 2008 | KitchenAid K45SS Classic Stand Mixer
KitchenAid K45SS Classic Stand Mixer Logo
97 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
CJ C
CJ C
Steve Allison
Steve Allison
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
