SOURCE: hp laserjet m1522nf 10.0000 supply memory error
Try another toner. Most likely the chip on this one is bad.
SOURCE: how to intalling network sanner HP LaserJet M1522nf MFP
If your printer is connected in the Network and you are able to print fine than there is no communication Error.
In htan case if you are not able to scan then you need to upgrade the firmware of the printer and install it and i m sure your printer wiill scan scanning on the Network.
Mentioned below is the link to download the latest firmware of the printer.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=3442750&prodNameId=3442754&swEnvOID=228&swLang=8&mode=2&taskId=135&swItem=ma-70811-2
However before you start sending firmware to the printer you need to make sure that printer driver is installed on the PC.
Thanks and Regards
Neeraj Sharma
SOURCE: HP 3050 Engine Comm error
I have a HP 3050 three in one and I keep getting a engine comm error
had same problem. It turns out I didn't remove all plastic caps from new cartridge (mine came with orange-color). Once I did that, problem solved.
SOURCE: How to Reset HP Laserjet M1522nf security password
Hi the easiest way is a nv ram
1. Turn the printer off
2. Hold down the down arrow and the cancel button
3. Reboot the printer while holding the buttons and hold until permanent storage is displayed. Let go of the buttons and wait for the ready message on the display.
This reset will clear all of your saved settings and contacts, if networked print
out a configuration report after resetting the printer to view the ip
address (IPV4). If the IP address has changed you will need to update
the print driver's port tab and update the port.
Good Luck
Al,
[email protected]
