SOURCE: How do you use bit torrents & key gen to
You don't - you go and buy them and you won't then be breaking the law!
SOURCE: imy autocad 2010 software does
Try to use 000-00000000 as your serial # and 00000 as the key. This used to give you a 30-day trial.
SOURCE: i ALREADY INSTALL THE AUTOCAD
The serial number should have come with the product.
If you have the CD it should be on the CDs envelope or on the box somewhere.
When you run the activation (should come up automatically the first time you run AutoCAD, but can be run from the menus too). an activation dialog should come up showing the activation code. The program can be activated over the internet, if you choose to do that it should be more or less automatic.
The program can also be activated over the telephone. If you choose to do that then call the number provided and give them the code number from the dialog and they will give you the activation code.
Enter the code in the dialog and the program will be activated.
