Is the security light lit or flashing , located on instrument cluster ? Anti-theft system problem possibly , disables the starter . Your best bet , have it towed to a qualified repair shop or have a mobile lock smith come to where the vehicles an have a new key programmed . Nothing you can do or try to do .
possible incorrect pitch of the ring gear of the flex plate to the pinion gear of the starter
not all flex plates have the correct ring gear for the starter
? 3:23 www.youtube.com/watch?v=I2SUGIvYAWc Jul 12, 2013 - Uploaded by Raybob216
My 04 exployer left turn signal and break light not working fix loose wires behind ... bulb and come to find out wire had popped out of the harness. ... How to Change Ford Explorer 2002 Flasher Relay for Hyper Flasher Relay ... How To Install Replace Turn Signal Wiper High Beam Switch Ford Ranger 95-98 ...
I asked a frend about your problem and he said there isnt one, he said when you use the clicker, your moveing away from the car, so you get an audable sound to let you now it's working, when you use the key your at the car and you now whats happening.
Sounds like the torque converter clutch is not dis-engaging. (It locks up the torque converter at highway speeds for fuel efficiency.) Try unplugging the connection at the transmission, and plugging it back in. If no help, have a shop check out the torque converter clutch operation.
This depends on what system you have installed in your truck. If you have push button 4x4 with auto locking hubs then you would put your vehicle in neutral and press the 4x4 button. You then drive froward about 10 feet and the auto locking hubs should then be engaged.
If you do not have push button control and you have a gear shifter which controls the transfer case you would push the level in 4x4 hi or low depending on what you want (while in neutral) then drive forward about ten feet so the hubs lock. If you have manual locking hubs you need to manually engage the hubs before you put it in 4x4 mode,
then the transmission has failed or has sticking engagement solenoid in trans pan, have the fluid and filter replaced and see if that corrects the problem
