If the tail lights, low fuel light, temperature gauge, and fuel gauge are not working, there could be several possible causes:
- Blown Fuses: Check the fuses for the tail lights, low fuel light, temperature gauge, and fuel gauge. If any of these fuses are blown, replace them with a new one.
- Loose or damaged wiring: Inspect the wiring for the tail lights, low fuel light, temperature gauge, and fuel gauge. Look for any loose connections or damaged wires. Repair or replace any damaged wires and ensure all connections are tight.
- Faulty sending units: The low fuel light and fuel gauge are connected to the fuel sending unit in the gas tank. The temperature gauge is connected to a temperature sending unit on the engine. Check these sending units for faults, and replace them if necessary.
- Faulty instrument cluster: The instrument cluster itself could be faulty, causing the temperature and fuel gauges to not work. A qualified mechanic can test the instrument cluster to see if this is the issue.
It's also possible that the trike has a separate electrical system for the tail lights, and that this system is malfunctioning. A qualified mechanic can test the trike's electrical system to determine the cause of the issue.
