Microwave was working fine, then the display went blank and the interior light just flashes.
SOURCE: SHARP R-316F
easy to fix you need to cut the tracks to the led lights then solder 2 wires to the leds next use a 1k resistor on one of the wires then conect it straight to the power surply just after the bridge rectifier noteing+ and -
SOURCE: Microwave interior light
Very easy to replace...at least on my JVM1790. Remove the top vent....the long plastic thing that runs along the top of the MW. Two screws on top of the micro. Behind the charcola filter (if you installed one) is an access area to the bulb. remove one screw and the entire assy comes out. Simply R & R the bulb.
SOURCE: Sharp Carousel Microwave has no power
I too believe that a "protection fuse" was possibly blown. It would need to be found and get replaced. Hopefully it is just a fuse and nothing else because the way it sounds to me, the microwave may be damaged.
Good Luck!
SOURCE: Microwave electrical problem
Unplug, take all the screws out from around the case. Remove case. There is a fuse inside (Without Model number I can't tell you right where it's located) It looks like one of the old round car fuses only it's white colored. It's made of ceramic. Replace it and put unit back together. This is a common problem when one does what you are saying yours is. Be thankful that's all, if you had anything working it would be something major and would be cheaper to replace unit if it a counter top model.
Please rate solution
SOURCE: GE Profile Microwave - JVM2070SK02 - when turning
We see (and repair) this
a lot. The problem is on the control panel, which
we regularly repair nationwide by mail for $39.95 postpaid in about a
week.
At
our Web site, you can get details of our service, plus we have a video
available showing how to remove a typical
over the range control panel assembly in under 5 minutes.
This light failure often
occurs when a bulb goes out and the filament
shorts, or when the bulbs are removed or installed without first
unplugging the oven from the power line. Either can cause such a
failure on the controller.
Sometimes this will also
affect the exhaust fan operation, too. The lights and fan can be
inoperable or stuck on too.
Feel free to contact me directly (and please remind me of your
full model number) for more information & help.
We're
happy to help you with free advice and we'd appreciate your
thoughtful rating of our answer.
William E. Miller
[email protected]
http://www.microwavedisplay.com
