A manual for the Motherboard 945GCT-M/1333 (V3.0) can be found at the link below. Gateway's support site does not recognize 945GCT-NM as a valid Gateway model number.
http://download.ecs.com.tw/dlfileecs/manual/mb/eng/p4/945GCT-M1333_v3.0/22_945GCT-M%201333%20(3.0)_Low.pdf
SOURCE: no video on bootup 945gct-NM
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA the leads from your ((motherboard to your hard drive)) make sure they have secure dust free connections and are not faulty or just replace them they might be faulty if its a 40 pin flat ribbon type it will be the first to fail make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electical extensions even something as small as an electrical fan and its lead can cause you problems computers need all electrical power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error make sure your graphics card is securely seated with no dust built up or in the socket if you remove your graphics check the socket to make sure its dust free restart your computer then reinstall it this should activate found new hardware wizard hope this helps
