Whirlpool LER4634J Electric Dryer Logo
A
Anonymous Posted on May 26, 2014
Whrilpool light in dryer not on and the dryer will not come on
The power button when pressed does not maek the dryer come on and the light is not on in the dryer either
1 Related Answer
liveone15
  • 61 Answers
  • Posted on Oct 22, 2009
SOURCE: whrilpool dryer wont start set selector press
Sounds like something you will need a repair man for.Unless you are mechanically inclined it sounds like it's electrical.
Why my Whrilpool Drier AWZ 555 is not drying the clothes and power light is blinking?
Check to make sure it's getting full 240vac power. Some or most driers are fed from two breakers in the box. If one is tripped you aren't getting enough power. That could be causing the blinking light. Also check for enough exhaust flow to prevent overheating.
2answers
My GU2475XTVY0 built-in dishwasher has the "Normal" light flushing since yesterday morning. We pressed "Cancel" button, other buttons, and finally turned the power off and on, but it didn't do anything. Do...
Hello- The touch control pad is failing and must be replaced. If unit is under warranty, get it serviced. This control is about 125$. Let me know if this info helps. Thanks-Ed
I need wiring diagram for whrilpool ler5636kq1. timer
Good luck finding one. I look at the wires. They are marked with the same letters as that of each dryer terminal. I have a plain jane dryer manual from whirlpool but I doubt it will help much.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Whrilpool dryer wont start set selector press start and all lights blink and dryer makes clicking nosie from apprears bottom rear
1helpful
Whrilpool le7800 will not start at all
make sure the door switch is ok. Usually you will be able to hear a click if not then the door switch can be broken, Or it could be the fuse stat in the dryer.
Whrilpool gas dryer lgn2000jqd stops heating half way
u have a maf coil the dryer has a prim/ second coil remove and replaced come in a kit
May 12, 2009 • Dryers
1helpful
Nothing happens when I push the start button on my Gas Dryer
Three things you can check the door switch is it clicking? The thermal fuse you want to make sure there is continuity or worse case would be your motor.
1helpful
Whrilpool Duet Dryer - Model GEW9200LW0
The repairman just took the front off my dryer and cleaned the dust from the components, now it works just fine, and I had the same problem as you.
Top Whirlpool Dryers Experts
Virgil Watts
Paul Bade
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
