Locked up doing a microsoft quick scan now no monitor only led lights left
SOURCE: Boot to black screen fpr hp pavillion dv2000
Solution by CJ and Brian is most likely the best answer.
SOURCE: hp pavilion dv2000 notebook will not boot up
hp says the problem occurs with amd based computers. my research on forums says that its linked to a bad bios, or bad mother board, or bad gpu (nvidia). symptoms include: blank screen w/ indicator lights on, wireless connection problems....hp support put out a warranty enhancement, but it looks as if customers w customized laptops dont get service (like me). on further inquiry i found that theyre only servicing amd based products because they received a significant amount of problems with them. i guess they havent documented many cases w intel based products, so please do ur part by contacting them.
SOURCE: hp dv2000 won't turn on...
dude, I almost gave up.. try this link. Apparently lots of people experienced this problem so HP gave an extended warranty for models like these.
Here, more info: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&lc=en&cc=us
To contact HP in North America call 1-866-671-7362 from 6:00 am to 11:00 pm MST, 7 days a week.
SOURCE: my screen has shrunk on my HP Pavillion DV2000
check your screen properties. right click on your desktop/properties/settings .. see if that helps. turn it to max resolution.. apply then reboot.
SOURCE: display not working for HP pavilion dv2000
Try to attach your computer to an external monitor to see if it is a screen issue or a motherboard issue. If the computer does not pick up on the external right away, try to toggle it by holding down the Fn key and striking F4. If you get a picture on the external, then you have only lost the screen and the motherboard shouyld be fine.
Testimonial: "How do I do that?"
