I need to know how to change on my radio control E.Howard watch.
SOURCE: My E. Howard & Co
Yes the battery needs to be replaced. The battery should be replaced by trained personnel to avoid damage and to maintain the water resistance according to factory specifications. After battery replacement the hands of your atomic watch must be repositioned to 12 o’clock. The hands can be advanced either incrementally by repeatedly pressing the T2 button or rapidly by holding the T2 button. Pressing the T2 button briefly advances the minutes, holding the button down lets the minute hand move continuously until the T2 button is released. (The minute is also shown in the LCD helping you to set the correct time.) Your watch now uses its integrated quartz movement. Please note in this mode your watch cannot display the date. The time you have set is retained until your watch is able to receive the signal from the WWVB transmitter again. The date will then also be set and displayed in the LCD again. After your atomic watch automatically receives the WWVB signal the watch will be set to Pacific standard time. You must then either press the T1 button to confirm the time or set the desired time zone. ---------------- La Crosse Technology, Ltd provides a 10-year limited warranty on the movement of this product against manufacturing defects in materials and workmanship. All other components of the watch including the lens and strap are warranted for 1-year against manufacturing defects in materials and workmanship. For warranty work, technical support, or information contact: La Crosse Technology, Ltd 2809 Losey Blvd S. La Crosse, WI 54601 Phone: 608.782.1610 Fax: 608.796.1020 e-mail: [email protected] ---------------------- Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
SOURCE: Can you send me instructions
the maker claims setting to be automatic!
The signals for Casio watches are sent out during the night, so I would assume that your watch will be the same.
Do nothing and wait till tommorow!
If nothing happens, then go to http://www.lacrossetechnology.com/support/manuals.php and select the manual from the list.
SOURCE: how do i change the
There is no way to change the date manualy on the watch. It is done by radio waves. Please read below.. If you need the manual go to the link below. The atomic watch's internal computer processes the received time signals and automatically synchronizes the hands, date and the change over between daylight saving time and standard time as well as the leap year accordingly. The signal reception and synchronization occur automatically every night and manually upon
demand.
http://www.lacrossetechnology.com/ehow23/manual.pdf
