SOURCE: No audio on RCA d52w20
i don't know what it is but my tv is doing the same thing if you find out will you please let me know.
SOURCE: RCA D52W20 52 in. Rear projection hdtv problems
can you tell me if the light blinks when you press power? If so let me know and I can help you diagnose the problem.
the circuit board behind the power on and off button needs to be replaced very easy fix.. good luck everyone
SOURCE: RCA D52W20 52 in. Rear Projection HDTV power light blinking
Liz, yes it is a power supply problem, better question is; low voltage or high voltage power supply ? count the blink code, it should repeat the code, once you have the code call your local tv shops and give them the model number of your tv and the blink amount and they`ll tell you price to fix, gl, video-tek
SOURCE: DOES MY 2003 RCA HDTV MODEL #D52W20 HAVE A BULB
no, this set has 3 crt's no replacement bulb in this one
