I need to disassemble the printer to get at the waste ink reservoirs as the printer will not function until the reservoirs are either replaced or cleaned
SOURCE: waste ink near full for Canon Pixma 780
http://www.tradebit.com/filedetail.php/3901083-canon-pixma-mp780-service-manual
Genuine Canon Service Manual for the MP780
SOURCE: Canon MP980 All in one printer - Error 6000
Error 6000 tells you that the paper feed roller is not turning, check for any foreign oblects in the paper path, a flashlight and small mirror is the best way to look.
SOURCE: my printer needs to have the waste ink reset how do I do this
You can try this....
But this happens because the waste tank is full. You need to locate it and use a paper towel to absorb the waste ink. Whenever the printer cleans itself ( when a new cartridge is installed, for example) some ink is cycled into this chamber. So if you reset and it is full, overflow may occur.....
SOURCE: MP760 - how to disassemble? (waste ink absorber almost full)
You really don't have to disassemble it. What would be helpful tho is some sort of long needle-nose forceps. Tho I bet you could get by with a pointy chop-stick in a pinch. There are two waste-ink absorbers on the right, and one spongy thing on the left. With the 'hood' open, allowing you access to the cartridges, you should be able to see the pads. Get a Petzl light on your forehead, you'll need a lot of light! The sponge on the left is covered by a small clear plastic trough that channels the ink into the sponge below. With enough poking and prodding you should be able to get all these out, rinse with water, dry with a hair dryer, blot out the pad areas with a kleenex, and pop them back in. Good Luck!
SOURCE: Where can I buy the waste ink absorber pads for both printers?
Hi
The waste ink are in the inside of your printer you need to get at it to clean out, but after this you got to reset it after you cleaned it or it will still not work, you may not have to get inside to clean it try this first to reset it.
Reset CANON PIXMA IP5000 printer
To reset the counter or to find out about it’s reading you have to use the service mode.
Turn off the printer, push the resume button and keep on pushing.
Press the power button and keep on pushing. Now let go off the resume button,
but not the power button. Push the resume button twice, then let go off all buttons.
You are now in service mode.
To leave the service mode, give the power button one push.
Push the resume buttons once, after that the power button once.
The first information page appears.
Push resume twice, then power once: You get the second page.
Newer PIXMA-printers print the first page as a test for the nozzles.
The second page contains a lot of information.
Our advice: Print the second page before and after reset of the waste ink counter.
Only then can you be sure that the reset was a success.
To reset the waste ink counter right now, push resume four times and after that power once.
Important: Before starting with normal printing again, switch off the printer.
That gets you out of service mode.
Then switch on the printer again and print, as you like
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
