Hello & Welcome to FixYa
F01 error in your whirlpool double oven means a bad electronic control board that needs replacement. Please get back if your need more help.
Kevin
F1 Error indicates a bad control board and the control board
(electronic control) should be replaced to solve this issue. Hope this
helps...please post back for further assistance.
You have a stuck keypad or a bad electronic oven control. Try pressing all buttons at random several times each to unstick a faulty pad. If that does not work the EOC must be replaced.
It is quite possible the control electronics have failed. There are separate relays for the upper and lower ovens. Ours recently failed the upper oven with the same symptoms and it was the electronic control. The other part is the overheat thermal sensor for the oven may be out.
you can check your manual if ariund for possible 5 year warr on electronics. if so they will still require an authorized servicer to replace they wont ship to you. and all ercs are different so ordered as needed.
