I have gone thru the scan 3 times now - auto, std, and irc and it finds nothing. What am I doing incorrectly?
SOURCE: can't get Satalite remote model IRC 451 to work with my tv
theres nothing much i can tell you, i searched google through maybe 5 pages, everyones having the same problems. i'll keep looking for you though
SOURCE: what is the difference between HRC, IRC, Std and
Usually standard broadcast is is the default setting,some other cable company use HRC and URC, these are ways to transmit or deliver their signal trough cable wire,ask comcast cable for their transmission type.
SOURCE: what is the comcast remote code for the supersonic
Download the user manual for your remote here
http://www.comcast.com/corporate/customers/customer_support/remotes.html
SOURCE: I need the codes for a supersonic tv to program directv
Ask the remote code search engine. They will figure it out for you.
SOURCE: Samsung 40'' LN40C530F1F Setup Help Needed
I would suggest calling your cable service provider. I just purchased the same TV and experienced the same problem/question. I have ATT Uverse and called and spoke with technical support. They said that you need a HDMI cable and the cable settings need to be set to HRC (High Resolution Compatible) or someting like that. The other 2 settings are analog modes! I had mine originally set to STD I just randomly picked this setting and had my TV conected to the cable box useing a coax cable, this is why it looked strange. I hope this helps? I will be picking up a HDMI cable on my way home from work today and will change my cable setting on my Samsung to HRC. If this does not fix the problem I will repost tomorrow, but I am sure this is the solution. Happy viewing!
