Kodak ESP 5 Printer Logo
A
Anonymous Posted on May 25, 2014
I put new black in it said the black was out. I put new in, it worked for a couple of days and now it prints so light you can't read it.l
After many cleanings, head refreshings, and "head allignments" the color printing is very light...especially the black. I've put in all new inks and the print is still very light. The new ink...
Try putting a bit of isopropyl alcohol in the bottom of the cartridge holder where the ink goes through and letting it sit for a couple hours then putting the cartridges back in and running the cleaning cycle a few times.
The alcohol should help dissolve the dried ink in the print head.
1helpful
Flashing red light wont print last cou[ple of days printing black lines every now and then and now wont print tried putting new roll in still wont work
Autosence your printer by turning it off and then hold down the feed button while turning it on and release feed button when light flashes red.
Samsung CLX-3160 I put in a new black toner because the older one
This is the problem in the Black developer in the Imaging unit. Please call samsung or visit authorised service center
I put in new color and black cartridges a couple of days ago and was able to print okay. Now I keep getting ''Remove and Check Black Cartridge'' prompt. I've taken out Black Cartridge, turned off printer,...
hope you put back both cartridges before trying again..try wiping the tip of the black cartridge before replacing it..then activate the head cleaning process..
4helpful
2answers
The following printhead(s) has a problem Black/Yellow[K/Y].
Simple solution is:
Replace the Black and Yellow Print Catridges. The print heads are mounted to the bottom of the catridges and these, depending on whther they're from HP or not. can have a hard time conducting electricity properly, and in turn.. spitting ink out properly.
Also happens often with aftermarket Catridges because HP puts chips on the catridge. be sure to put an HP catridge. Sometimes you get what you pay for :)
3helpful
6answers
Black ink not printing
Fix ink cartridge
I had same problem. I must have ran the clean cycle more than 30-50 times over a period of days. That never made any difference. I was about to toss the whole thing but figured I would try one more thing. If it didn't work I would be in no worse shape. Here is what I did.
Took an almost empty black cartridge and inject a lot of 100% Acetone to dilute ink. Left some black in it since I didn't want to think it was empty. Inserted this cartridge and ran the cleaning a few time. IT WORKED. I used my word processor program and filled a page with large bold font characters and printed a page or two. Each page cleared more nozzles. After doing this cleaning/printing a number of time, I put in the full good cartridge. Ran the cleaning a few time to eject any of the Acetone diluted ink. Ran the printed page a few time to remove more of the diluted ink.
Everything seems to work now.
28helpful
11answers
Kodak 5300 series printer/is not printing black and white that is legiable
There is a known problem with premature failure of the printhead. I called Kodak support at 1-800-421-6699. They will go through a short procedure with you, and then should offer to replace the print head free of charge. After I called (no wait, and an native English speaking operator), I received the replacement in two days.
9helpful
10answers
No black print
I work for kodak with these printer's.
I provide tech support for them.
For this problem all i would recommend is doing the deep clean on the printhead twice, Doing it more then twice is a waste of ink and if it doesnt fix it the second time it won't.
Also replacing the black ink cartridge.
Also calibrating the printer has worked for me a few times.
I would not recommend cleaning the printhead manually, thats more of a chance to break it then fix it.
I would just recommend calling into the kodak tech support and getting a replacement printhead to fix that clogged nozzel problem.
2answers
Black and yellow ink not printing
This is what worked (so far) with my Dell1.gif AIO A940 printer1.gif that wouldn't print black ink.
It worked for awhile when I chose photo/glossy paper, but then it quit printing again (see below).
PRINT, PROPERTIES, PAPER SETUP, SPECIALTY PAPER, PHOTO/GLOSSY
I got it to print, again, by putting SEVERAL papers in the feeder (instead of just 1) - there is a sensor that is supposed to automatically detect paper type, and it might not be working right, especially with one or only a couple of sheets.
Top Kodak Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
