220volts
That can be found here:
Rainbow D4 SE field 110v
GoodVac.com
800-775-6586
SOURCE: rainbow d4c
All four sides of the inner shell in the top can be pushed in to remove inner shell. I tried to take my switch out and gave up after several attempts at pinching the plastic tabs inward that hold it to the case. even with all four tabs pushed in the switch didnt want to push all the way out.
SOURCE: rainbow d4c
If it just quit running, it could be the cord. If you have a meter, you can check it to make sure it isn't broke. Take out the 4 I think, screw from the bottom, the top half should come off, then you get to the switch and the end of the cord. Check the motor brushes also, if they are worn down, they may not be conducting and the motor won't run. It gets involved, so don't know if you want to do this at home.
SOURCE: What's the difference between the rainbow D4C SE
the se has a newer updated version of the power nozzle. the power nozzle is smaller.the d4c is older
than the se. the attachments are pretty much the same and the se is a darker color than the
d4c
SOURCE: I just purchased a rainbow D4C, after purchasing i
There is only one difference between the D4 and the D4 SE, which stands for D4 (Special Edition). It is the exhaust plug screws in on an SE and snaps in on a regular D4.
Then the SE-PE came along, which stands for (Special Edition-Performance Edition) which has a more powerful motor, with larger motor brushes, for more power and runs on 9.8 amps, where the regular SE and D4 run on 8.8 amps. It also has the newer PN-2 power nozzle, which is very much like the latest E and E2 series Rainbow vacuums, instead of the earlier rectangular ones, that have the bottom metal plate, which will rust. You can upgrade your D4 to one of these, though you will need the electric hose with gas pump style handle, with the built in power corn in it.
They are all D4 models.
If you have any more questions let me know. I am a Rainbow seller, and a Rainbow expert also.
Thank you,
Ralph
