Everything is in the positions as required and all it does is click
SOURCE: My Pride Celebrity 3 wheel scooter, keeps suddenly
Hi. Sounds like a loose connection, either on the battery terminals, or on the battery lead connectors.
When your machine suddenly stops, does the battery gauge also turn off?
Can also be caused by a worn or stuck motor brush.
If none of these ideas help, can you give us a better description of what goes wrong?
Good luck. Neil.
Testimonial: "Thanks very much for the quick reply, I will get someone to check it all out. "
SOURCE: Pride Celibrity 3 wheel electric scooter. The motor isn't working
the click is the electric brakes releasing , most likly the problem you are having is the brushes in the motor may be shot cheap easy fix on each side of the motor there should be what looks like a flat head screw those are the brush covers remove them and check them replace as need , otherwise the motor may be shot
The manual freewheel lever is in the (forward) freewheel position.
Remove the key from the key switch, then push the manual freewheel lever to the drive (rearward) position and restart your scooter. The manual is at...
http://r.duckduckgo.com/l/?kh=-1&uddg=http%3A%2F%2Fwww.pridemobility.com%2Fpdf%2Fowners_manuals%2FUS_Scooter%2FUS_Celebrity_X_om.pdf
