What does lights blinking six times and elect. windows not working at the same time mean?
Lights blinking six times. Which lights are you referring to? The ford explorers use sequences of blinking lights on the dash to signal different errors. If you have the cars computer checked for error codes it will give you the cause of the problem.
If it is the 4x4 lights blinking this is a signal of about four different possible problems the computer has detected. Your problem will be one of these. From memory I think one of these is for a problem with the doors electrics. As you windows have stopped working it is quite likely this is the error that your computer has picked up & is telling you to get checked.
Get the windows fixed & the error codes wiped. If the windows were the cause of the problem the lights shouldn't start flashing again.
Marty
