How can i change the name of my company for the fax funcion on a bizhub 7218?
  • Office Equip... Master
  • 6,850 Answers
SOURCE:
Descargar controladores bizhub 7218
any chance english
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jan 12, 2014 | Konica Minolta bizhub Office Equipment &...
How do I change the company header on this fax machine?
with function key go to entry mode and own number set .change name and number
May 20, 2010 | Sharp FO 5700 Plain Paper Laser Fax
I want to change the name (My caller ID)when I fax how can I do that It show up as Holy Dreams that name of our former company. I want it to show as our new company. How do I do that
I believe you wish to change the "Station ID" on your MFC-240C. This setting will print out your company name and other header info on your faxes:
1) Press the <Menu> key
2) Press <Up> or <Down> Navigate to "Initial Setup"
3) Press <OK>
4) Note: Your station ID is already set, therefore the machine will prompt you to choose: (1) change, or (2) exit without changing - choose (1) to change
5) Enter your fax number, then press <OK>
6) Enter your company name using the dial pad keys. This may take a little practice. Press the dial pad key the correct number of times to produce your desired letter. Use your (>) right navigation key to advance to the next space. If you entered a letter incorrectly and want to change it, press the left navigation key to move the cursor under the incorrect letter.
7) Press <OK> when finished
8) Press <Stop/Exit> to resume normal operation
There! You should have it. I hope this helps!
Brother MFC 240C Station ID
Mar 03, 2010 | Brother Multi-Function Center MFC-240C...
I need to change the old company name to the new one
Here is a link to the users manual. You just need to change the registration information.
http://usa.copystar.com/americas/jsp/upload/resource/13716/0/FAX-SYS-L-ENOG.pdf
Mar 20, 2009 | Copystar CS-2550 All-In-One Printer
Want to change the Header
Press Data registation,on usersettings press set,press the arrows untill you get unit name,press set,insert you company name there.
To change the fax number-under usersettings select unit number and change it to your number.
Jan 12, 2009 | Canon LaserClass LC 8500 Plain Paper Fax
BizHub 350 Network Fax - Prints instead of faxing
Set the Gateway TX to "Allow"
1. Press the Utility/Counter button.
2. Touch Admin Management
3. Enter Password (The default password is 12345678)
4. Touch Admin2
5. Touch Network Settings
6. Touch Network Settings1
7. Touch Scanner Settings
8. Touch Gateway TX
9. Set Gateway TX to Allow
Dec 23, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
A change in admin settings
see that the printer shows ready for copy, then try to go to admin menu
Sep 25, 2007 | Konica Minolta bizhub C250 All-In-One...
Ricoh Aficio 5000L Fax Printer-Adding names to Group name
On every fax i've worked on, you cannot edit groups. You have to delete the group and start over.
Apr 17, 2007 | Ricoh FAX5000L Plain Paper Laser
43 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
