Error 30 means "Malfunctions related to the shutter have been detected". Recharge the battery, remove and replace it after about 20 seconds, then do a reset to default settings through the camera menu. If it still won't work you'll need send it in for repairs.
First Try a different lens on the Camera to see if its the body or the lens, Most of the time its the lens, If its the lens then it has to be repaired by a repair shop, Cost to repair is $68.00, Body: Check in the menu settings under Display reset it there to the length of time you want it to go on or off.
Remove the battery, press and hold the power button, or turn the power switch to ON position(depends on the option available in your Camera) for more than 30 Seconds and then reinsert the battery to resolve the issue.
The 'fluttering' is a pre flash used to help the camera focus in low light. The internal flash isn't a powerful flash and is usually only good enough for subjects up to about 2m away in reasonable light also to light a subject that is back lit. Try putting the camera in manual mode (M) 1/60sec on f5.6 flash popped up review it and make adjustments accordingly i.e. open up or shut down the aperture as the flash usually syncs at 1/60
Yes, it could be an issue with the camera or the battery. The easiest way to find out is to try a different battery in the camera. If this works then the most likely culprit is your battery. If this doesn't work then your camera requires service.A good camera store should let you try one of their batteries in your camera.
Full details are in the "Shoot by Ambiance Selection" section of the manual (page 64 in my copy). If you need a copy of the manual, you can download a copy here.
in manual mode, will not try to focus itself, my be the manual auto switch is faulty, or the focus related mechanism not rotating the lens, open the lens carefully check the focus motor and gear set (engine is the technical term)
