Cameras Logo
A
Anonymous Posted on May 24, 2014
Menu hidden menu
How do I unhide a hidden row in the body of a large spreadsheet? Lotus 123
Question moved to a better category.
Some of the rows or columns in my spreadsheet are hidden. How do I see all rows or columns?
  1. Select the area of the spreadsheet where rows or columns are hidden. To select the entire spreadsheet, select Edit ? Select All from the main menu or press CTRL + A
  2. To show all rows, select Format ? Row ? Show from the main menu
    To show all columns, select Format ? Column ? Show from the main menu.
https://www.google.com/search?q=unhide+a+hidden+row+Lotus+123
How do I delete previous destinations
1. From the Main Menu, tap the Go To icon.
2. Tap the Previous icon.
3. Tap Delete All to clear the list.
4. To confirm the deletion, tap Yes
If htat doesn't work:
There is a hidden service menu that will return the unit to as it left the factory.
Go to the system menu:
On the menu bar ( the top bar where it says Sytem Settings)
Tap...
Left corner twice,
Right corner twice,
Left corner once,
Right corner once.
It will bring up a hidden menu.
The first thing on the hidden menu is "reset for first use".
Press that and you have done the equivalent of a hard reset.
You want to be very careful when in this menu as if you select the wrong tab you might lock up your unit. This is a backdoor hidden menu that is not commonly known.
How do I access my hidden menu
If your using Windows & just click on the computer tab and then at the left top of the screen click on properties and then choose folder options menu and then click on the view tab. Here on the view tab you can uncheck hide system files and folders and any hidden folders or files will now be visible. Careful here, do not mess or delete any system files or you will trash your operating system and it will not boot back up! Search for your hidden menu you mentioned and you should be able to view all files and subfolders within that hidden menu now. After you are done restore your computer back to the normal default mode by checking the box hide system files and apply the changes. Good luck. Regards, Dennis
Mar 02, 2015 • Cell Phones
Kyocera kona hidden menu
To get into the service menu, press 111111 like you were dialing a phone number and then press the key above the back key which should bring up a menu. In that menu, there is an option called service. Select that and you should have a menu up.
Jun 26, 2014 • Cell Phones
How do i access my hidden menu on my zte wrap
either hit the house button on the main screen or hit the tripple line button on the lower left hand side to bring up another hidden menu
When i add an favorite site in favorites menu i can see it in the favorites menu its hidden not alowd to see
control panel,folder options select view scroll down to hidden files and folders tick in show hidden files and folders
hope this helps
4helpful
2answers
Can't find hidden media folders
Follow these steps to hide or show pictures on the BlackBerry smartphone:
  1. On the Home screen of the BlackBerry smartphone, click Media.
  2. Go to Pictures.
  3. Open the picture that you want to hide.
  4. Press the Menu key and click Properties.
  5. Select the Hidden check box and click Close.
Follow these steps to show a picture on the BlackBerry smartphone:
  1. Click Media.
  2. Press the Menu key and click Explore.
If the picture is in Device Memory,
  1. Click Device Memory.
  2. Press the Menu key and click Show Hidden.
If the picture is in Media Card,
  1. Click Media Card.
  2. Click BlackBerry.
  3. Press the Menu key and click Show hidden.
Additional Information If the computer is set to Show all hidden files and folders, the BlackBerry smartphone user should be able to view all hidden pictures by using Roxio® Media Manager. However, pictures cannot be hidden or shown using Roxio Media Manager. If a picture is on a media card and the computer is set to Show all files and folders, pictures can be viewed, hidden and shown by using the removable disk drive.
7helpful
Need to retrieve hidden pics
  1. First open your Media app
  2. Then press menu and select Explore
  3. Select Media Card then BlackBerry then Pictures
  4. Then press menu and select Show Hidden
  5. Then scroll to the image that was hidden and press menu and select Properties
  6. Then this window will open and uncheck the Hidden checkbox
I somehow delted the icon for my internet browser
Hi. To get your browser icon back, (probably it's been hidden) you only need to go to your main menu, press the menu button again, and you should see the "Show All" option, select it and now you'll see the hidden icons in grey color. When you come over the hidden icons and press menu button, you can select to hide or show them. And when you do the "Show All" steps again and select it again, this time you'll hide your icons selected as hidden. Hope this helps.
2answers
Tried the 543210 code but no menu appears , am i missing something
In order to acess the hidden menu you first have to first click the AM/FM button then on youre remote click the dvd setup button once there press 54321 listening to the beeps. Then hold 0 untill the hidden menu comes up
Top Casio Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Casio Camera Expert? Answer questions, earn points and help others
