Electrical Supplies Logo
C
Curtis DePoyster Posted on May 24, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why does my generator start constantly?
Kohler 14/20RESA Generator After a very nearby lightning strike, the auto start appears on continuously even when I completely disconnect the remote wires. Putting the generator into Auto mode results in instant cranking and starting and won't stop until I manually turn the generator off. Any ideas what portion of the control fried or needs replacing (or any suggestions on fixing)? Basically, I've lost the ability to remote start as it appears to be always in start mode.
J.D. Browning
Level 3:
  • Master 2,760 Answers
  • Posted on Jun 04, 2014
J.D. Browning
Master
Level 3:
Answers
2760
Questions
0
Helped
1013804
Points
6696
If a lightning strike was anyplace close (30 yds) it's a safe bet your gonna have to replace the control board in generator also Id have a qualifyed tech ck out your auto transfer switch ,I bet he''ll find that you fried your coils on your switch too , do that before changing control board cus if ya hook up a new one to a bad coil ya just bought two of them
2 Related Answers
Steve
  • 12 Answers
  • Posted on Nov 29, 2012
SOURCE: Kohler 12RES only starts on second try
Check gas pressure. Oc is over crank. Means tried to start but did not.
Steve
  • 12 Answers
  • Posted on Nov 30, 2012
SOURCE: I have a Kohler 12RESM1 propane generator with oc/uu code
U need to make sure that the relay driving ur auto start stay closed all thru the crank cycle.
2answers
I have Kohler marine Genset It run in manual mode but when I start it in auto it do not start due to indication of LCL .need help
There might be two reasons for the failure of generator auto start.
1. It is the ATS automatic conversion control device that does not issue the start generator command after the mains power failure or phase loss operation, or the self-starting relay failure, which causes the generator to not start itself. This situation is relatively rare.
2. It is the generator start battery failure, and this kind of situation is relatively more.
I have a Kohler Confidant 5, model 5ckm21 generator in my RV, serial # 326827, spec# 101228. It worked fine one evening and the next day it wouldnt stay started unless the start button stays depresse
no 14vac coming from generator to control board.--cause can be regulator board on end of generator---dirty brushes or worn out brushes==b1 and b2 winding open that outputs the 14vac--my problem was blown regulator board
2helpful
Generator starts for no reason
You have a short in the remote start wiring, incorrect wiring terminations, or a defective control sensing in the transfer switch
2helpful
The monitoring system of our Kohler propane generator has sent a "UU" message. What does this mean as it causes the generator to shut down 10 seconds after starting? Also how can this be...
The monitoring system of our Kohler propane generator has sent a "UU" message. What does this mean as it causes the generator to shut down 10 seconds after starting? Also how can this be corrected?
1helpful
Generator won't start. Screen showing OC.
OC means OVERCRANK safety circuit stopped the auto start-up so you wouldn't burn up the starter. There is a reason the generator didn't start. Low battery, not enough fuel pressure, clogged air filter, bad starter... You just have to eliminate as many as you can visually. Rebooting the generator should clear the OC condition and you can try to start it manually.
1helpful
3answers
1helpful
Kohler Confident 7 model 7CCKM22 generator
sounds like a relay should be latching one it has started
Top Kohler Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
