HP PhotoSmart C4480 All-in-One Printer  InkJet Logo
A
Anonymous Posted on May 24, 2014
How to restore hp c4280 printer to default - HP PhotoSmart C4480 All-in-One Printer InkJet
4 Related Answers
Anonymous
  • Posted on Dec 14, 2007
SOURCE: Printer PS C4280 All-in-One Won't install to HP Pavilion BT938?
i cant install the sofweart
Anonymous
  • 105 Answers
  • Posted on Jun 20, 2008
SOURCE: Hp c4280 printer/print cartridges
Have you checked to make sure that you have the correct replacement cartridge?
In general if it simply will not go into position and you know you have the correct cartridge, then you need to take it back to where you bought it and request a replacement - because it is defective.
Anonymous
  • 23 Answers
  • Posted on Feb 17, 2009
SOURCE: How do I install ink cartridge for hp photosmart C4280
To replace the print cartridges
1. Make sure the HP All-in-One is on.
CAUTION: If the HP All-in-One is off when you open the print cartridge door to
access the print cartridges, the HP All-in-One will not release the cartridges for
changing. You might damage the HP All-in-One if the print cartridges are not
docked safely when you try to remove them.
2. Make sure you have letter or A4 unused plain white paper loaded in the input tray.
3. Open the print cartridge door.
The print carriage moves to the far right side of the HP All-in-One.
4. Wait until the print carriage is idle and silent, and then lightly press down on a print
cartridge to release it.
If you are replacing the tri-color print cartridge, remove the print cartridge from the
slot on the left.
If you are replacing the black or photo print cartridge, remove the print cartridge from
the slot on the right.
1 Print cartridge slot for the tri-color print cartridge
2 Print cartridge slot for the black and photo print cartridges
5. Pull the print cartridge toward you out of its slot.
6. If you are removing the black print cartridge in order to install the photo print cartridge,store the black print cartridge in the print cartridge protector or an airtight plastic container.
7. Remove the new print cartridge from its packaging and, being careful to touch only
the black plastic, gently remove the plastic tape by using the pink pull tab.
1 Copper-colored contacts
2 Plastic tape with pink pull tab (must be removed before installing)
3 Ink nozzles under tape
CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching
these parts can result in clogs, ink failure, and bad electrical connections.
8. Slide the new print cartridge forward into the empty slot. Then gently push the upper
part of the print cartridge forward until it clicks into the socket.
If you are installing the tri-color print cartridge, slide it into the left slot.
If you are installing a black or photo print cartridge, slide it into the right slot.
Work with print cartridges 69
Maintain the HP All-in-One
9. Close the print cartridge door.
If you installed a new print cartridge, the HP All-in-One prints a print cartridge
alignment page.
10. When prompted, ensure plain white paper is loaded in the input tray, then press the
button next to OK.
NOTE: If you have colored paper loaded in the input tray when you align the print
cartridges, the alignment will fail. Load unused plain white paper into the input
tray, and then try the alignment again.
11. Place the page print side down on the scanner glass and then press the button next
to OK to scan the page.
When the On
Please Don't forget to rate this solution. Thanks.
Anonymous
  • Posted on Aug 30, 2009
SOURCE: Install new color caridge on C4280 HP printer
open your printer cover and you can easily install your caridges
MY HP PHOTOSMART C4280 aLL-IN-ONE PRINTER HAS NO CATRIDGES WHAT CATRIDGES DO I USE
Access the manufacturer's web-site: http://support.hp.com
Enter 'C4280' and do the search.
Click "Get Started" or "Product Information"
to find the correct ink-cartridges.
Start up disc for the hp c4280 all-in-one
Here you go:
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?tmp_rule=21907&tmp_task=setupCategory&lc=en&dlc=en&cc=us&product=3192753
2helpful
3answers
HP Printer C4280 says "USB not connected"
Install software that is twain compliant.
Maybe the HP bundle that came with the printer.
Also Paint Shop Pro,Adobe Acrobat.Photoshop etc.
Use the usb cable after the install of the HP drivers then you may change the default location of where scans are saved.
1helpful
Windows keeps re-installing HP Photosmart C4280
I have a customer with Windows XP and the same issue. Told him to unplug the printer cable when starting the computer and/or restarting it. Wait until all auto-start programs have loaded, including and specifically the HP Monitoring Utility program. Once Windows is up and he's at the desktop, THEN plug the printer cable into the computer. He's been doing that for several days now with no duplicate printers installed.
Drivers reinstall frequently
just give your system a restore ponit by clicking on start menu, go to all programms, click on accesories, under accessories click on system options under that go to system restore and restore your system to the date you install the printer. then re install the printer again
k24674
Grand Canyon Tech
Grand Canyon Tech
