Question about Karcher 2500 PSI Pressure Washer
I have anexcell 2600 waher and pressure stopped mudstream water input OK
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 76 Answers
I'd love to offer my help, but need the full model #.
look on the base frame for the model # sticker.
it maybe something like XR2600
Posted on Jun 11, 2014
SOURCE:
How can I stop the siphon?
Are you using the black nozzle? Switch to a different nozzle. If you are not using the black nozzle the siphon fitting is bad.
Sep 24, 2014 | Karcher G 2600 XH 2600-PSI Honda Gc190...
All outflow stops when I start the motor on my Troy-bilt 2600 pressure washer. What's up?
Could also be crack/leak in HP pump. If it were left in cold weather without antifreeze, I'd check there first. Part + labor might warrant new washer if more than a couple years old.
Sorry.
Aug 11, 2014 | Troy-Bilt TROY-BUILT 91215 - TROY-BUILT...
How do I fix a Karcher 2600 PSI pressure washer has water in oil..
you mean water in the pump oil ??? or engine oil ???
im suspecting pump oil... you didn\'t seal it properly or you have a crack somewhere in the main housing. rarely is it viable to repair these pumps... if you search a little you can find replacements pretty damn cheap !!!
Aug 09, 2014 | Karcher G 2600 VH Gas Pressure Washer
I have a 2600 Troy bilt pressure washer.When I start the pressure washer,no water comes out the nozzle and the nozzle is not clogged either.I took the nozzle/gun off and there still was'nt any wat
If when you take the High Pressure water hose off the pressure washer pump no water will come out they you may simple have the bypass valve stuck. You may need to just remove the outlet fitting and clean the bypass valve.
It would be helpful to know the model number of the pressure washer or the pump.
Mar 29, 2012 | Garden
Gcv160
High likelyhood of your intake screen/filter being stopped up with debris that was in the water hose.
Other than that, more information would be needed. Like, does no pressure mean it doesn't seem to spray at all (or nothing more than the water hose is pushing water through the system with the engine off)? Or does the pressure come up a little and there is a pulse you can feel in the hose/trigger gun? Any other little details you notice can provide clues as to the root of the problem.
If it was just a stopped up intake, and this fixes your problem -- please take a sec to rate me. Thanks!
Don
Mar 24, 2012 | Honda Black Max 2600 PSI Pressure Washer
Power waher was working fine nad than preassure stopped and water is coming out of bottom no pressure in gun
sounds like something busted or whether a part or a hose on the inside busted take apart and see what it might be if it is a part that can be replaced or jb weld it may still can be used or if recently bought return it
Jun 24, 2011 | Black & Decker 1700 PSI Electric Pressure...
I have a honda 2600 pressure washer. After running fine for a couple of seconds the water will stop flowing out the tip. It is receiving water,but will not flow it to the pressure hose. I even disconnected...
This happens when air gets inside the hose. An air bubble of sorts is in the hose and will not build pressure until you blow the air out of the line. Start the pressure washer, turn on the water. pull the trigger on the gun. It will spitter and spatter and come to a trickle. release the trigger on the wand. Pull the trigger again and it will eventually work it self out.
Jun 13, 2011 | Honda Black Max 2600 PSI Pressure Washer
No spray
I have a G 2600 VH psi which isn't listed here, I have need to order a part that isn't listed, this part goes into the detergent tank that monitors the difference between types of nozzle is attached to hose, what is it call?
Jul 06, 2010 | Honda Maxus Pressure Washer MX5222
Water continues to fill after it should have
first does it over flow.if not pull your drain hose up from the drain till it is aleast the same level as the back of the waher control panel.
If the Drain hose is to far down in the pipe this will cause the water to drain out by gravity.the other least likely problem is a bad fill pressure switch.
Sep 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Coin operated maytag top load waher whirlpool design how do u adjust water level on pressure switch
water level on the pressure switch is pre set make sure that nothing is in the pressure switch hose it connects from the pressure switch to the tub, if no obstruction then replace the water pressure switch
Apr 24, 2008 | Washing Machines
Karcher 2500 PSI Pressure Washer Logo
102 people viewed this question
Top Karcher Garden Experts
Martin Grech
John Trevino
JOHN LAPIER
Are you a Karcher Garden Expert? Answer questions, earn points and help others
