SOURCE: there is fluid on the clutch hydraulic cylinder
under the hood,next to the brake master cylinder.on some models the 'lid'is held on with a bolt.
SOURCE: ATF fill station
The ATF stands for Automatic Transmission Fluid which controls your power steering. You might have observed your steering has gotten a bit more stiff... or will eventually get to this. This ATF is different from the hydraulic fluid which controls your brakes. You need to take it to a BMW automechanic who would top it up. It is sold in containers like hydraulic...you will buy it and give it to mechanic for refilling. The container for this is in the bonnet just below the windscreen almost at bottom of engine. also ensure that the lid is not open and the container is not broken in any way to leak the ATF
Cheeers
SOURCE: how much hydraulic fluid is needed
i honestly do not know i just fill to the top of the resevoir
